Introdução
My microscope is old (very old) and before throwing it away, why not teardown it?
NB: If you notice that there's too many errors (in language, mostly), please correct me. Thanks.
O que você precisa
The microscope package (that's right, some items were lost and the box suffered)
The back of the box with all its items.
The useful piece of the microscope package: the microscope (not very surprising...)
Now, let's begin the operation: we'll begin with the pedestal. No need for screwdrivers, you just have to pull it.
After this, there's a screw. Let's remove it.
Once you did it, the battery compartment can be removed.
Note: if you want to remove the pedestal completely, you may need to cut the both wires.
Then, this rotative piece is, in a side, a mirror and in the another, a lamp (hence the 1.5x2 batteries in the step 2).
To remove it, you need pull a side. The rest will come alone.
The picture is a little fuzzy but we can see:
The bulb.
The support of this rotative piece.
The battery.
The cover which prevents the bulb to fall.
The mirror and the bulb location
