Introdução
Hello! Today i’m gonna show you how to disassemble Xiaomi Mi band 3 band. Hardest part of it is the shell because it needs extra force and prying but after it the insides are modular and straightforward.
O que você precisa
Opening the shell is the hardest part here, and it's difficult to separate them.
I've used jimmy and hot air gun to soften and slice trought the adhesive.
After cracking the shell you have access to the touch screen ribbon and the OLED screen.
Use a spudger to unclip the Hearth rate and the touch screen sensor ribbon
Unscrew two Philips PH00 screws at the bottom and use the spudger to lift it up.
Next remove the mainboard with the battery. Battery isn't glued to the chassis so it's easy to lift up.
Use Jimmy to pry up the hearth rate sensor and gently remove the vibration motor using tweezers.
To remove the battey you need soldering iron the - terminal of the battery is marked on the mainboard
Um comentário
I need that display for my mi band 3 I am really sad because I broke my display
