O que você precisa
Remove the 4 hidden T10 screws.
Lift and remove the bottom cover from the pump.
Remove the 3 T20 screws from black pump casing.
Carefully lift and remove black pump casing. There will still be one wire connecting to the main board.
Unplug connector on the main board, that attaches to the pump.
Unplug the 2 ribbon cables from the main board by sliding the tab out and removing the cable.
