Introdução
Our MacBook Pro 17" Unibody arrived on February 17. We immediately got to work disassembling it and posting teardown photos here. We comment on interesting changes and show some comparisons with other MacBook parts.
O que você precisa
We have it! Our patience has been severely tested by the month-long wait for this MacBook Pro 17".
We'll post updates on twitter about interesting things that we discover as we go. We'll also post interesting notes in our blog over the next few days.
Feel free to comment on specific steps as we go. If you have requests to see specific parts, we'll do our best to accommodate.
Look at all the accessories you get for $2799!
An 85-watt power adapter
An 87 page user's manual
Two software restore DVDs
One small black cleaning cloth
We were half-expecting Tim Cook to jump out of the box. Didn't happen.
There is NO Mini DisplayPort adapter included. That'll be $29, please.
you get one with an iMac
also, $2799 is ALOT
Physical dimensions: 0.98 x 15.47 x 10.51 inches and 6.6 pounds.
For comparison, the 15" model measures 0.95 x 14.35 x 9.82 inches and 5.5 pounds.
There's something almost spiritual about the blackness of that screen. Much to our dismay, it is not full of stars and David Bowman is nowhere to be found.
"He [Jonathan Ive, Apple's senior vice president of industrial design] understands that it's not about the object itself. It's about the experience the object will create"
– Victor Ermoli dean of the School of Design at the Savannah College of Art and Design in Dec. 08 Mac|life Magazine, Meet the top 10 Apple Influencers
Can u put up a side by side comparison of the different models? I can't visualize just #'s.
Citação de Locke:
Locke, we'd love to do that but sadly we don't have a 15" unibody right now! If you find a picture online, I'll post a link to it.
Citação de RyanD:
Was there anything stopping you from changing the battery, what is that sticker like tag, does that break or indicate you've removed the battery?
No, the sticker doesn't break. I don't think there's any way they could tell you took it apart if you were careful.
Citação de kyle24:
Citação de garyh:
Thanks! It's a cool site, but the comparison didn't load for me, I just got a spinney wheel. I'll try again later.
Citação de garyh:
Worked for me in Firefox, not tried any other browsers.
Yup, better now, thanks!
Citação de kyle24:
Many thanks, I had and identical question (probably badly formulated) on page 2
That's exactly what I wanted to know.
didn't recieved mine, but for setting the Glasspad "click", removing the batery seems to be the only way
Thanks again
Tidbits from Apple System profiler:
12,820 mAh capacity. Yes, that's 12.8 AMP HOURS. Let's hope it actually lasts the 1,000 discharge cycles that Apple claims.
Our battery already had 3 cycles on it! I wonder if the famous factory girl tested ours.
A 2 GB DDR3 1067 MHz RAM chip is installed in each slot, as expected.
The hard drive is a 320 GB Hitachi HTS543232L95A02 SATA drive using the NVIDIA MCP79 AHCI controller.
The model that we bought has the 'low-end', 2.66GHz Intel Core 2 Duo processor with 6MB on-chip shared L2 cache.
The 25th anniversary of the first Macintosh computer was January 24th, 2009... I enjoyed looking at the Evolution of Apple Design Between 1977-2008.
The lower case. Apple's using wide, thin black rubber feet on the Unibody Pros, a departure from the small stubby bumpers on the Aluminum revisions.
There are ten Phillips screws around the perimeter of the lower case to remove:
Seven 3 mm screws
Three 14 mm screws
The computer's serial number is engraved in the aluminum lower case, not the upper case like the other Unibody machines.
We removed the screws, and we're rotating off the lower case now.
The second picture reveals the beautiful internals. Look how huge that battery is!
The serial number is now engraved on the lower case, not on the Unibody upper case as they do on the 15" Pro and 13" Unibody.
Citação de 0501701:
could you take a picture of the motherboard at an extreme close up view and then maybe a straight overall view so that we get an idea of how things are organized inside?
Here's a high res closeup.
How exposed is the vent where the screen is connected to the base? And also, is the keyboard sealed underneath? I've had small bugs fly into my keyboard before and it's driving me crazy to think I could have dead bugs in my computer.
yes it is under all this
Disconnecting the battery connector.
The second photo is removing a 2 GB DDR3 RAM chip.
Citação de kouma:
Can you try running the laptop without the battery, i.e. using only the power cable. Would it run?
Yes, it would work fine.
Citação de kouma:
Since I only use my laptop while its on my desk, thus always connect to the AC adapter, why shorten my battery's life if it can work without it.
You can work without the battery, but it's quite useful to have it in there. The battery's essentially a "backup," powering the computer should anything happen to the AC power. If you accidentally unplug the computer and don't have a battery, you risk ruining your hard drive or just losing information.
It's also not good for the battery to sit there with no charge. Read up on how to prolong the life of lithium ion batteries if you'd like more detailed information.
To remove the hard drive, unscrew the two small Phillips screws holding the black plastic hard drive bracket to the chassis. Pull up on the white plastic tab and lift the hard drive out of the case, being careful not to strain the SATA cable.
Carefully disconnect the Serial ATA cable.
Citação de Industro:
Do you have any idea who makes the 256GB SSD that comes as a build-to-order option?
A budy recieved his UB17 with a 256SSD
It looks like it's a Toshiba
Picture of the Apple's UB17" 256GB SDD : Toshiba 256GB Unibody SSD
Model number :
256GB Fujis 655-1526A
Fujis THNS256GE8BCAA
Screenshots of www.serialata.org validation references
The customer who recieved It, seems disapointed, the SSD max out @ 100MB/sec and is 2.5 less performant than the Intel X25 (80GB MLC)
http://www.marketwire.com/press-release/...
Does anyone know if the the 1 TB SSD would fit inside? That would be an upgrade!
Ignoring all manufacturer warnings, we are removing the non-removable battery. Hold your breath!
There are three tri-wing screws holding the battery to the Unibody case.
is the Battery removal "visible" : does the sticker broke or stretch easily?
I've heard that the glass trackpad "click" can be refined by gently setting a screw under the battery (actual working tips for the Unibody 15" and 13")
or does this access will remain forbidden for people not wanting to void the warranty?
Would it be possible to replace the annoying slot-in superdrive with another SATA storage device (say, a 500GB HDD) ?
- Would there be enough headroom (9.5mm or better) ?
- What connector/part to use ? Would the existing SuperDrive connector fit a SSD or HDD ?
- How challenging would it be to secure a 2.5" mass storage device in the SuperDrive emplacement ?
Thanks for any help with this, I'm about to buy one of those laptops, and my experience with slot-in drives encourages me to consider alternative uses for that wasted space in the shell. :)
Come to think of it... an extra fan in there couldn't hurt: I'm told the 9600GT tends to run hot, and I'm going for the 2.93GHz version of the processor.
Citação de AcD:
Check this out: http://store.mcetech.com/Merchant2/merch...
Removed the battery! That was pretty easy.
It's only a matter of time until you'll be able to buy this battery online from companies like us.
Removing the battery in the 17" is reminiscent of the MacBook Air-- several screws to remove the lower case, a few screws on the battery, and it's free.
The battery is Apple model #A1309, 7.3V 95Wh (12820 mAh).
Tree huggers everywhere will be relieved to know that it "contains no Mercury (Hg)."
The battery weighs 20.1 ounces (1.25 pounds or 570 grams). That's 20% of the computer's weight!
These pictures look great. Everything is so clean in there.
Citação de dave:
I'm always impressed with the layout that apple does inside their computers. I've taken apart other "Non-Apple" computers and the insides always seem cluttered and disorganized, with lots of plastic everywhere. Granted, I have a limited number of non-apple take-aparts, kudos to Apple's Engineers.
Anatel is the Brazilian telecoms regulatory agency and the logo is the agency's logo:
The Bluetooth board is right behind the optical drive, next to the hinge.
It's very nice that Apple moved this out of the display assembly (where it is located in the MacBook Unibody and 15" MacBook Pro Unibody). No longer does a Unibody owner need to replace their entire display assembly ($$$) when their Bluetooth goes out.
It has an Anatel logo on it: BCM93046MD MINI 003WWA080264 FCC iD:QDS-BRCM1037.
Like the other Unibody machines, the Airport card is in the display assembly clutch cover.
The 8x slot-loading SuperDrive (DVD±R DL/DVD±RW/CD-RW).
The internal design of this machine is pretty consistent with the 15" MacBook Pro. We'll be posting some part comparison shots later to show relative sizing.
Citação de Rwilson:
What model optical drive is in there?
The SuperDrive is a SATA SuperDrive just like the other Unibody machines we've taken apart. However, this drive was manufactured by HL, and not Panasonic like the drives we saw in the 13" and 15" Unibody machines. The label printed on the drive says "Model: GS21N." Apple System Profiler reports the model as "HL-DT-ST DVDRW GS21N" and revision "SA17."
Citação de luke:
Do you know of a BD-ROM or BD-RW that we could swap for this older DVD drive? It seems a shame that Apple has such high-end everything but such a run-of-the-mill CD/DVD drive.
Oops, I noobed: see comment mistakenly posted in step 9, please.
Hi,
I am also interested to replace the optical drive by a BD-Rom DVD/CD writer like this:
http://www.sony-optiarc.eu/products/blur...
Would this fit?
Thanks for your answer
Hi xanthalas and friends,
The Blu-Ray drive will not fit in the MacBook Pro 17". The drive needs
to be 9.5 mm in height in order to fit into the laptop.
Citação de miro:
Thanks Miro. Can somebody tell me what drive is used (Vendor and ID) as I didn't find such small drives in height.
Thanks.
Citação de xanthalas:
Thanks.
Hey xanthalas,
I stole this from Luke's February 17th post: "The SuperDrive is a SATA SuperDrive just like the other Unibody machines we've taken apart. However, this drive was manufactured by HL, and not Panasonic like the drives we saw in the 13" and 15" Unibody machines. The label printed on the drive says "Model: GS21N." Apple System Profiler reports the model as "HL-DT-ST DVDRW GS21N" and revision "SA17.""
On my machine, the big wire going from the left corner to the board covers the screw.
Its a tiny metal connector, and under magnification you can see little tabs on each side
To remove this wire from the board, use your fingernails to hook the tabs and pull (horizontally) towards the DVD drive
This guide gives details on how to remove each connector:
Rather than show all of these comparisons, how about showing every single step, every little insignificant piece of whatever that you remove, move to take something out or to make taking something out easier... I've got the MackBookPro 17" back together and have about a half dozen parts that go somewhere, but who knows.
How about putting some arrows pointing out connectors that are being removed??? Not just listing 6-7 of them and assume we know what it is and more importantly where it is...
The bottom of the logic board.
The component density is amazing.
There are four Samsung K4J10324QD-HC12 chips, likely video RAM for the NVidia 9600 chipset.
On left: 15" Unibody fan. On right: 17" Unibody fan. Below: A North Carolina 'first-flight' quarter.
The Sunon manufactured fan says 'MagLev' on it. That's interesting! Part #: MG45070V1
Sunon's site says, "By using magnetic levitation force (MagLev), these fans feature zero friction with no contact between shaft and bearing. With excellent rotational stability, the MagLev fan eliminates vibration and typical wobble and shaking typically experienced in fan motors."
"MagLev also provides excellent high temperature endurance that results in long life."
Apple's used similar fans in MacBooks in the past.
Citação de SpaceAge:
Does the unibody 15" use a MagLev fan as well then?
Not that we've seen.
I'm curious about the airflow on these fans: do they suck in and vent out both through the backside black heat sinks, or is air sucked in through the bottom-side openings (through which you see the fan blades on the pictures) then forced out through the heat sink ?
If the second is true, I'd imagine the fans are generating an "in" airflow all over the motherboard (between the mobo and underside plate), using every available crack in the case joints as intake, which presumably means it will build up a fat air dust crust all over the components in no time.
If the fans both intake and exhaust mainly through the rear ports/heatsinks, how is the rest of the machine cooled (besides CPU and GPUs) ?
Removing the Phillips screws securing the perforated metal covers to the Unibody. These covers seem to protect the ribbon cable connections for the trackpad, keyboard, express card, and the serial ATA hard drive. Apple hasn't used metal shields like this before.
Bottom of logic board with fans removed.
Disconnecting a number of connector cables:
LVDS, keyboard backlight, iSight, speaker, IR/sleep sensor, trackpad, keyboard, Express card, hard drive, and battery indicator light
Top of logic board.
The speakers are mounted on the left next to the ports.
The heat sink covers the two NVidia chipsets and the processor.
This machine has 512 MB video memory for the NVidia 9600M. The 9400M chipset shares 256 MB of system memory. You have to log out to switch between graphics chipsets.
Removing the black heat sink and heat conduit.
Second image: The processor and two NVidia chipsets revealed!
Intel processor: Intel 5831C024 SLGEL AV80576T9550 2.66 / 6M / 1066
No surprises there: 2.66 GHz, 6 MB L2 Cache, 1066 MHz bus, just as advertised.
It looks like they weren't so messy with the thermal paste this time. ;)
Citação de badmoon:
the second set of speakers should be under the DVD burner, the disassembly doesn't show It for now.
We added a photo on step 22 showing the speaker positioning.
What revision is the Firewire chip? They used rev: 6 of the bad Agere/Lucent one. I have read Apple has aknoweledged that there are some problems, and that there are a rev: 7 of the chip already out in some external cards. This could be very important for some firewire audio interfaces e.g. like the RME FireFace 800.
Hi, is there a way to change out the nvidia 9400/9600 for a different chip, say a 8800 or 9800?
this is probably a really noob question but I had to ask
Citação de wantsamac:
Unfortunately, the video processor is soldered to the logic board and much too hard to replace without mechanized soldering tools.
We removed the heat sink thermal compound so you can see the die markings.
Left image: Intel processor. No die markings!
Middle image: NVidia L901B138 0902B3 PB9487.000 MCP79MXT-B3
Right Image: NVidia 50N3BF 0850C1 NK6791.S1W NB9P-GS-W2-C1
Citação de navicaph:
is that cpu soldered on?
Yes, unfortunately the CPU is soldered to the logic board. Apple hasn't offered a laptop with the CPU on a separate board since the G3 Pismo in 2000.
Why there are 2 nvidia chip sets on mother board , and which one is a graphic card among 2 chip sets
Left: 15" Unibody logic board
Right: 17" Unibody logic board
What's different? The biggest difference to you is the additional USB port. Oh, and $800.
The low-end 15" board that we took apart in October only has 256 MB video memory (Samsung RAM soldered onto the board). The high-end 15" and this 17" have 512 MB video RAM.
Citação de jamesb:
What are the dimensions of the logic boards on the 17" and 15"?
The 17" Unibody board is about 5.5" by 9.5" (14 cm by 24 cm). The 15" Unibody board is the same height, but only about 8.25" wide (21 cm).
Do you guys have apple tv repairs done yet? They all have the same glitch lately that they keep restarting over and over again and my apple provider here in Iceland is saying it's not apple's fault.
I need to buy a new one they say!
Thank you so much for this web page and very professional work. I enjoy coming here every day reading!
We removed the display assembly.
Citação de UltraNEO:
Hiya, Is it physically impossible to dismantle the display section? As yet, I've not seen any images posted by anyone, not even yourselves.
The glass front panel is glued firmly to the rear panel. We haven't tried to liberate it. It is possible that heat might loosen the adhesive, but it's just as possible that the heat will smoke or break the glass. As far as I know, there isn't a feasible way to get in there.
Citação de ben:
What if dust particles get between the glass and the LCD panel? Would there be no way to clean that out? This part concerns me.
Thanks
Citação de Factor:
Thanks
As far as i can tell from the descriptions of the manufacturing i have come across, the panels are sealed so dust shouldn't be an issue.
Can anyone confirm this?
Citação de mm1121890:
Which brand and model of LCD panel is used in the unibody 17" MacBook Pro?
We don't know yet. If we disassemble the display further we'll let everyone know.
Citação de MacManNZ:
Can you please disassemble the LCD so we can see the LED backlight?
thanks that would be much appreciated
keep up the great work!!!
citing Ben above:
It is possible to get the glass panel off the display assembly. It is quite easy to break since it is glued much like modern iphones/ipads. That said, it can easily cheaper to buy just a display panel and a replacement glass than to buy a whole display assembly so even with the risk of breaking the glass, it’s not a bad deal. You can buy the glass at OWC. I’ve bought from elsewhere, but the glue on the other ones didn’t stick well enough. Shop around to make sure you can get the parts you need before you dig in though.
Clockwise from top left: Logic board, heat sink, display, unibody upper case, battery, hard drive, speakers. Fans, RAM, and optical drive are in the center.
There you have it! Be sure to check back often for more first looks, guides, and quality parts!
Citação de wuntorsi:
This is clockwise, not counterclockwise :)
Thanks ^_^
Savvy writing ! For what it's worth , you are requiring a a form , my friend found a sample form here"http://goo.gl/HM9wjM".
8 comentários
I wonder if the battery can be fitted to the 15" by moving the harddrive to where the superdrive is located and completely removing the superdrive. I would rather have more battery life than the superdrive. Anyone up for the challenge? Can someone please measure the dimensions of the battery?
Where are the accelerometers located?
Citação de ccfman2004:
There are none! the only ones are the hard drive sensor which park it for impact but people also use it as accelometers!
Citação de apple4life:
not true, idk where it is, but i removed my HDD, and booted from usb SSD( which stays stationary) and the accelerometer still works
I am trying to replace the memory on a new (2010) MacBook Pro 17". After removing all the screws on the bottom, the bottom still does not want to come off. It feels like something is holding it on underneath the touch pad. Any hints on how to get the bottom off of it? Thanks.
There are two metal tabs (visible in one of the Step 6 photos) that snap into two plastic clips next to the battery. They should release as you gently lift the bottom cover. Be sure to press them back together after reassembly.
if anybody has a teradown of the top case for kb replacement that d be awesome
I started getting the RSS problem on my A1297 about a year ago so I finally decided to replace the thermal paste. To my surprise I was missing 1 of the 8 heatsink hold down screws and there is no connector from my heatsink into the main board. The connector on the main board is there (as in your pictures above), but there is no connector coming off the heatsink.
Does the heatsink for the A1297 have a connector to the main board?
Someone please run SwitchResX on a 17" unibody and use the "Export DDC" function to extract the display information. Please post the model number of the LCD panel used.
mm1121890 - Responder
Hi I just did it is an LG Philips LP171WU6-TLA1. No Info could be found via google on this, seems to be too new.
Psion - Responder
Hi, I could not see the wifi module, can you identify it?
ibweaponx - Responder
