Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Dual USB Connector, use o nosso manual de serviço.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: passo 1, imagem 1 %32
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: passo 2, imagem 1 %32 MSI Dual USB Port Bracket Teardown: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Phillips #1 Screwdriver
    $5.49
    Comprar
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: passo 3, imagem 1 %32
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
Membro desde: 04/07/10
415 Reputação
Autoria de 2 guias
Um comentário
Why does it need its owe usb header just for the LED's.
Rick Acker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 34
Últimos 30 dias: 54
Duração total: 7,818
