Pular para o conteúdo principal
Esta desmontagem está em andamento – Atualizar periodicamente para ver as últimas alterações!
Ferramentas utilizadas neste teardown
Introdução
Teardown of the Logitech S120 Slim Mini Stereo Speakers.
  1. Desktop Computer Speakers
    • Desktop Computer Speakers
    • Weight: 1lb
    • Height: 6.22 in
    • Width: 2.67 in
    • Depth: 2.51 in
    • Power: 2.2W (RMS)
    • RCA and 3.5mm jack inputs
  2. Remove the speaker grills using a thin, flat object such as a flathead screwdriver.
    • Remove the speaker grills using a thin, flat object such as a flathead screwdriver.
    • Insert the tool where the grill connects to the chassis just above the logitech logo.
    • Pry upwards until the grill releases
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Insert the flathead screwdriver in the seam between the speaker chassis.
    • Insert the flathead screwdriver in the seam between the speaker chassis.
    • Use force to jam the flathead screwdriver into the chassis.
    • Drag the screwdriver around the chassis until the two sides separate.
  5. Using a phillips head screwdriver, remove the screws holding the PCB, transformer, and speakers to the chassis.
    • Using a phillips head screwdriver, remove the screws holding the PCB, transformer, and speakers to the chassis.
    • Pull the PCB, transformer, and speakers from the chassis.
  6. The driver board contains several components
    • The driver board contains several components
    • Stereo Amplifier: TEA2025B
    • 5mm LED power indicator
    • Potentiometer and on/off switch
    • Decoupling, bypass, and AC coupling capcaitors
bglidden95
Membro desde: 14-02-2014
130 reputação
Autoria de 1 guia
I took mine apart, only the Speaker that contains the On/Off Volume— Potentiometer. That Speaker fell off my table and hit the floor landing on the Volume control knob, since then the Speakers do not work unless I insert something to keep pressure on the Volume Control’s shaft. Is it possible to obtain and replace the potentiometer/On/Off Switch…?
James L Parmenter - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 114
Todo: 1,024
