Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Logitech M510, use o nosso manual de serviço.
  1. Logitech M510 Teardown, Logitech M510 Teardown: passo 1, imagem 1 %32
    • Let's get started!
  2. Logitech M510 Teardown: passo 2, imagem 1 %32
    • Flip your mouse over
  3. Logitech M510 Teardown: passo 3, imagem 1 %32
    • Remove the batteries by pulling on the tab.
    • If you do not plan on putting it back together, ensure you dispose of the batteries properly.
  4. Logitech M510 Teardown: passo 4, imagem 1 %32
    • Take the battery pull tab that is circled in red and tape it to the area that is circled in blue
    • This allows you to access the screws that are hidden by the battery pull tab
  5. Logitech M510 Teardown: passo 5, imagem 1 %32
    • Unscrew the two screws that are circled in yellow.
  6. Logitech M510 Teardown: passo 6, imagem 1 %32
    • Remove the tape
  7. Logitech M510 Teardown: passo 7, imagem 1 %32
    • Now you can easily separate the bottom and the top of the device.(Just give it a little tug)
  8. Logitech M510 Teardown: passo 8, imagem 1 %32
    • Okay now that we've got it separated we can have a sneak peek inside
    • The scroll wheel.
    • The battery area
    • Mouse buttons
  9. Logitech M510 Teardown: passo 9, imagem 1 %32
    • Now unscrew the screw that is circled in yellow
  10. Logitech M510 Teardown: passo 10, imagem 1 %32
    • Now disconnect the cable there is circled in blue by unplugging it from the logic board.
  11. Logitech M510 Teardown: passo 11, imagem 1 %32
    • We have taken apart the bottom half, So let's take apart the top half.
    • This is the on-off switch.
  12. Logitech M510 Teardown: passo 12, imagem 1 %32
    • Let's get started disassembling the top half
    • Remove the two screws circled in yellow.
  13. Logitech M510 Teardown: passo 13, imagem 1 %32
    • Okay now that we've got that done, lets continue
  14. Logitech M510 Teardown: passo 14, imagem 1 %32
    • Remove the screw circled in yellow
  15. Logitech M510 Teardown: passo 15, imagem 1 %32
    • Now you can pop out the scroll buttons.
  16. Logitech M510 Teardown: passo 16, imagem 1 %32
    • Now pop out the piece circled in yellow
  17. Logitech M510 Teardown: passo 17, imagem 1 %32
    • And there we go we have disassembled the entire mouse.
Xavier
Membro desde: 04/20/21
352 Reputação
Autoria de 1 guia
Equipe
X71FS Membro de X71FS
Community
1 Membro
Autoria de 3 guias
5 comentários
I’ve actually seen a model of this same mouse where optics sensor is MODULAR with a ribbon cable. So much better for repairability!
Giorgi - Responder
I don’t have this mouse, but an LX8 Cordless Laser Mouse. It looked quite similar so gave it a go, and presto! It opened up easily, I could get to all the internal bits quite easily and removed years of cat hair, tobacco grains and human oils which had formed felt mats around the moving parts and gummed it up completely! Now factory fresh and restored to full function - couldn’t be happier! Thanks Xavier!
Adrian Mann - Responder
It says the video is private.
Michael Norton - Responder
The video is private. But the instructions are good without the video.
Note that the front-side of the mouse has tabs that hold the pieces together, so mate the front of the mouse (the button-side) before mating the end closes to the batteries (and the screws)
Adam Goldberg - Responder
Thanks! It would be great if you showed how to take the wheel out - it has to be pried out of its seat in the front of the mouse. FYI for cleaning it only takes steps 1 thru 8 plus taking out the wheel.
PB - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 88
Últimos 30 dias: 354
Duração total: 9,164
