Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Logitech M Series Mouse, use o nosso manual de serviço.
  1. Logitech M235 Teardown, Logitech M235 Teardown: passo 1, imagem 1 %32
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: passo 2, imagem 1 %32 Logitech M235 Teardown: passo 2, imagem 2 %32
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: passo 3, imagem 1 %32
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: passo 4, imagem 1 %32
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: passo 5, imagem 1 %32
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: passo 6, imagem 1 %32
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: passo 7, imagem 1 %32
    • Done!
Daniel
Membro desde: 11/27/16
225 Reputação
Autoria de 1 guia
Equipe
4Bits Repairs Membro de 4Bits Repairs
Business
1 Membro
Autoria de 2 guias
8 comentários
Great work. Hope to see some more of your work
Mustafa karu - Responder
thank you..this helped me a looot
Sharnav Kundu - Responder
My M325 has NO SCREWS!!! Now what???
christcansaveyou - Responder
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - Responder
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 32
Últimos 30 dias: 117
Duração total: 20,889
