Ferramentas utilizadas neste teardown
Introdução
This is a step by step teardown of a Logitech webcam which is helpful if you are trying to build a stereo camera and remove the infrared filter or even simply adjust the focus.
Remove Camera from the box
Pull to remove the base
Attached to the white plastic is the privacy shade position sensor.
The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
The lens is threaded M10x0.5, and testing seems to indicate that the sensor is a CCD with global shutter.
