Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Linksys BEFW11S4, use o nosso manual de serviço.
  1. Linksys BEFW11S4 Teardown, Linksys BEFW11S4 Teardown: passo 1, imagem 1 %32
    • Waiting to be disassembled...
  2. Linksys BEFW11S4 Teardown: passo 2, imagem 1 %32 Linksys BEFW11S4 Teardown: passo 2, imagem 2 %32 Linksys BEFW11S4 Teardown: passo 2, imagem 3 %32
    • Remove antennas.
    • Remove nuts and washers around antenna connectors.
    • Push in antenna connectors.
  3. Linksys BEFW11S4 Teardown: passo 3, imagem 1 %32 Linksys BEFW11S4 Teardown: passo 3, imagem 2 %32 Linksys BEFW11S4 Teardown: passo 3, imagem 3 %32
    • Remove feet (with flat-head screwdriver, fingernails, etc).
    • Unscrew the screws.
  4. Linksys BEFW11S4 Teardown: passo 4, imagem 1 %32 Linksys BEFW11S4 Teardown: passo 4, imagem 2 %32
    • Pull apart blue front from black back with a LOT of force.
    • Slide and pull up bottom. (Make sure the antenna connectors get through.)
  5. Linksys BEFW11S4 Teardown: passo 5, imagem 1 %32
    • Twist and pull out antenna connector feeds.
  6. Linksys BEFW11S4 Teardown: passo 6, imagem 1 %32 Linksys BEFW11S4 Teardown: passo 6, imagem 2 %32 Linksys BEFW11S4 Teardown: passo 6, imagem 3 %32
    • Pull up RF shield from motherboard.
    • Unscrew the motherboard from the bottom.
    • Push the motherboard forward (as in this picture) to unlatch it from the bottom.
    Really would have appreciated if the photos were in focus
    Dominik Meyer - Responder
  7. Linksys BEFW11S4 Teardown: passo 7, imagem 1 %32 Linksys BEFW11S4 Teardown: passo 7, imagem 2 %32
    • Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
    • Push the card forward to deattach the pins.
    • Remove the card from the metal holdster.
  8. Linksys BEFW11S4 Teardown: passo 8, imagem 1 %32
    • Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
    • Macronix 29F040QC-90
    • ISSI IS41C16100S-50K
    • SAMSUNG ARM S3C4510X01-QERO
    • RMC RTL8019AS
    • Bothhands FB2022
    • Bothhands 40ST1041E
    • Kendin KS8995. Kendin has since been bought by Micrel.
  9. Linksys BEFW11S4 Teardown: passo 9, imagem 1 %32
    • Enjoy!
William McKinnerney
Membro desde: 04/18/10
65 Reputação
Autoria de 1 guia
2 comentários
what is that card inside this router
hartiTube - Responder
Thank you. I accomplished this task. Except my antenna wires were soldered to the board.
Darren - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 30
Duração total: 9,059
