Pular para o conteúdo principal
Ferramentas utilizadas neste teardown
Introdução
No, we're not having delusions of grandeur—this is the weapon of a Jedi Knight. And we're dying to see how it works. Today, we tear down a lightsaber.
We would be honored if you would join us. Check us out on Facebook, Instagram, or Twitter!
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Lightsaber, use o nosso manual de serviço.
  1. Listen up, nerfherders: We've got a lightsaber on the teardown table. Before we dive in, let's take a look at the specs:
    • Listen up, nerfherders: We've got a lightsaber on the teardown table. Before we dive in, let's take a look at the specs:
    • Manufacturer: Obi-Wan Kenobi
    • Crystal: single blue Adegan crystal
    • Production date: 22 BBY (Before Battle of Yavin)
    • Length: 15.8 cm
    • While historians debate which was the most effective saber design, our teardown unit hails from the old school: single blade, fixed length. No fancy crossguards here.
  2. Do you have the death sentence on twelve systems? Do you frequent wretched hives of scum and villainy? Then you probably don't want to see this saber firing up. If only we were Force adepts, we could release this interior clasp with a simple wave of the hand. Instead, we nudge it free with the tip of a spudger, revealing the crystal chamber. Seeing as this is his third lightsaber, Master Kenobi must have had long-term repairability in mind during its construction—it's incredibly easy to access the crystal chamber, with its single Adegan crystal.
    • Do you have the death sentence on twelve systems? Do you frequent wretched hives of scum and villainy? Then you probably don't want to see this saber firing up.
    • If only we were Force adepts, we could release this interior clasp with a simple wave of the hand. Instead, we nudge it free with the tip of a spudger, revealing the crystal chamber.
    • Seeing as this is his third lightsaber, Master Kenobi must have had long-term repairability in mind during its construction—it's incredibly easy to access the crystal chamber, with its single Adegan crystal.
  3. We'll get back to that crystal chamber a bit later. For now, we set out to open the saber itself. Let's start by unscrewing this clamp pin that secures the switch housing cover. With the pin removed, we're able to lift the clamp brackets out with no trouble.
    • We'll get back to that crystal chamber a bit later. For now, we set out to open the saber itself.
    • Let's start by unscrewing this clamp pin that secures the switch housing cover.
    • With the pin removed, we're able to lift the clamp brackets out with no trouble.
    • It seems Obi-Wan saw fit to include a charging port on his lightsaber. Lucky for us, he decided to use a standard DC barrel jack connector.
    • Unscrewing this small retaining ring loosens the port from the housing cover.
  4. We quickly dispatch a few tiny set screws securing the clamp to the body of the lightsaber. With the set screws removed, we extract the activation stud.
    • We quickly dispatch a few tiny set screws securing the clamp to the body of the lightsaber.
    • With the set screws removed, we extract the activation stud.
    • Pro tip: Sith happens. Fortunately, it's now impossible to ignite this saber by accident. For safety's sake, those of you tearing down a lightsaber at home should follow a similar procedure.
  5. Turning our attention to the top of the saber, we release the emitter shroud for inspection. The shroud appears to contain some sort of magnetic stabilizing ring. We're not 100% sure what a non-magnetically stabilized lightsaber beam does, but we're guessing it would be wise to put this back when we're done.
    • Turning our attention to the top of the saber, we release the emitter shroud for inspection.
    • The shroud appears to contain some sort of magnetic stabilizing ring.
    • We're not 100% sure what a non-magnetically stabilized lightsaber beam does, but we're guessing it would be wise to put this back when we're done.
  6. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  7. At first, we're a bit stumped by the crystal chamber cover. Turns out it's quite easy to remove with a half-twist and some well-targeted pressure. We subject the cover to a small battery of tests; it's made of an unknown material that is both nonmagnetic and nonconducting. With its smooth inner surface and segmented exterior, this looks designed to protect the wielder from the saber's extreme energy output, while possibly providing a small measure of cooling for the internals.
    • At first, we're a bit stumped by the crystal chamber cover. Turns out it's quite easy to remove with a half-twist and some well-targeted pressure.
    • We subject the cover to a small battery of tests; it's made of an unknown material that is both nonmagnetic and nonconducting.
    • With its smooth inner surface and segmented exterior, this looks designed to protect the wielder from the saber's extreme energy output, while possibly providing a small measure of cooling for the internals.
  8. With the shroud removed, the blade emitter comes into full view. Some say this ancient weapon is no match for a good blaster at your side. Whichever view you take, you have to respect this kind of craftsmanship.
    • With the shroud removed, the blade emitter comes into full view.
    • Some say this ancient weapon is no match for a good blaster at your side. Whichever view you take, you have to respect this kind of craftsmanship.
    • At this point, we've cleared the way to slide the clamp free and expose the switch housing.
    • Being photography buffs, we can't help but notice this clamp bears a striking—but entirely coincidental—resemblance to a 3-cell Graflex flash handle.
  9. We carefully remove the activation stud control bar. Stay on target...stay on target... We use our tweezers to make a trench run and take out a few nuts, loosening the next stage of the cylinder. Stay on target...stay on target... We use our tweezers to make a trench run and take out a few nuts, loosening the next stage of the cylinder.
    • We carefully remove the activation stud control bar.
    • Stay on target...stay on target... We use our tweezers to make a trench run and take out a few nuts, loosening the next stage of the cylinder.
  10. You won't find any regular old lithium ion batteries here! This lightsaber features a diatium power cell. The Force is strong with this one—the recharge port seems a tad redundant, as a properly-maintained diatium power cell will last indefinitely.
    • You won't find any regular old lithium ion batteries here! This lightsaber features a diatium power cell.
    • The Force is strong with this one—the recharge port seems a tad redundant, as a properly-maintained diatium power cell will last indefinitely.
    • The parabolic blade continuously recycles the power cell's energy output whenever the saber is not in contact with other objects.
  11. We had a slight weapons malfunction, but everything's perfectly all right now. We're fine—we're all fine here now, thank you. In case of any more surprises, we get a hand from a friend. Lightsabers are the leading cause of dismemberment in the quadrant; be sure to take precautions during repairs.
    • We had a slight weapons malfunction, but everything's perfectly all right now. We're fine—we're all fine here now, thank you.
    • In case of any more surprises, we get a hand from a friend.
    • Lightsabers are the leading cause of dismemberment in the quadrant; be sure to take precautions during repairs.
    • Next we unscrew the pommel cap, hoping to find a backup power cell.
    • No luck—we're able to remove an intermediary collar, but we don't find a reserve power cell.
    • Time to get a closer look at that crystal chamber.
    I couldn't belive, great job
    d11rcat - Responder
    Brad I am blown away, you are a true artist! I went to your site and checked out some of your other work and am just in awe. The ROTJ Luke is one of the coolest things I've ever seen!
    Chad - Responder
    Nice! Where can I get one? May The 4th Be With You!
    Eric Roberts - Responder
    I would love to get hold of a SlothFurnace saber... lol
    Khel - Responder
  12. That's no moon—it's the focusing crystal. We gingerly remove both the cycling field energizer and the focusing crystal activator from atop the crystal chamber. Misaligned crystals could cause a lightsaber to explode the instant it's powered on.
    • That's no moon—it's the focusing crystal.
    • We gingerly remove both the cycling field energizer and the focusing crystal activator from atop the crystal chamber.
    • Misaligned crystals could cause a lightsaber to explode the instant it's powered on.
    • Excited to get an unobstructed view of the primary crystal, we pull back the energy modulation circuits—and lift away the crystal chamber cooling fins.
  13. We finally arrive at the heart of the lightsaber, the primary crystal. This particular lightsaber uses a blue Adegan crystal, typical of a Jedi. Sith lightsabers are commonly made with synthetic red crystals.
    • We finally arrive at the heart of the lightsaber, the primary crystal.
    • This particular lightsaber uses a blue Adegan crystal, typical of a Jedi. Sith lightsabers are commonly made with synthetic red crystals.
    • Arguably the most important component, Adegan crystals are known for their Force-sensitive properties. Once properly attuned to the Force, a crystal is built into the lightsaber. Over time, the crystal will form a special bond with its wielder.
    • We peel away the three neatly packed crystal energizers from the primary crystal housing.
  14. We slide the rear grip and inert power insulator from the hilt. Though the rear grip resembles a heat sink, this design avoids the dramatic overheating problems seen in early lightsabers.
    • We slide the rear grip and inert power insulator from the hilt.
    • Though the rear grip resembles a heat sink, this design avoids the dramatic overheating problems seen in early lightsabers.
    • Looks like the extra space down here might be for upgrades, or possibly for the expert balance Obi-Wan surely requires of his saber.
    • With the disassembly complete, how will this beautifully crafted weapon fare in the repair arena?
  15. Lightsaber Repairability Score: 10 out of 10 (10 is easiest to repair) Extremely durable components make the need for repair unlikely outside of severe combat damage.
    • Lightsaber Repairability Score: 10 out of 10 (10 is easiest to repair)
    • Extremely durable components make the need for repair unlikely outside of severe combat damage.
    • Robust diatium power cell lasts the life of the device.
    • Recharge port allows for topping up the power cell in extreme circumstances.
    • No adhesive anywhere; all components are removable with basic tools.
    • Replacing the rare Adegan crystal requires a trip to remote star systems, or paying a hefty fee to an enterprising smuggler.
    • Lack of published repair documentation means you'll have to rely on your Jedi abilities to figure all this out. (But the Force has a strong influence on our weak minds, so we're still giving it a 10/10.)
  16. And now for the bits we didn't show you—because while lightsabers exist in a galaxy far, far away, this particular piece of Jedi kit was built by a true sabersmith here on Earth. Many thanks to the amazingly talented Brad Lewis, who generously loaned us one of his hand-crafted, better-than-movie-accurate lightsaber replicas for this teardown. You can see his complete build log for this lightsaber, and many others, at SlothFurnace.com—or, check him out on Facebook or Twitter! Thanks Brad! And may the Force be with you—always.
    • And now for the bits we didn't show you—because while lightsabers exist in a galaxy far, far away, this particular piece of Jedi kit was built by a true sabersmith here on Earth.
    • Many thanks to the amazingly talented Brad Lewis, who generously loaned us one of his hand-crafted, better-than-movie-accurate lightsaber replicas for this teardown. You can see his complete build log for this lightsaber, and many others, at SlothFurnace.com—or, check him out on Facebook or Twitter!
    • Thanks Brad! And may the Force be with you—always.
Geoff Wacker
Membro desde: 30-09-2013
77.557 reputação
88 Guias de autoria
Where can I buy this lightsaber???
gladgura - Responder
There are a few websites with light sabers... www.ultrasabers.com or www.saberforge.com
Bill -
Nice Teardown. Have the tools but no Lightsaber :(
Bernhard Grohs - Responder
Finally, I found out how to repair mine!!!
May The Force be with you!
Adrian - Responder
A joke a day keeps the doctor away........This is good for 14 days :-)
info - Responder
You guys did a great job! Happy to be part of it.
-sloth
slothfurnace - Responder
Really nice work in the finishing. Was the crystal an original, or is it 3D made ?
Neil - Responder
Neil, the crystal is an actual aqua aura quartz crystal. Hand selected for this build, and the mount machined to fit it.
slothfurnace -
Thanks for the information about the crystal.. nice work for the hand also..
Neil -
The fix is strong with you
hectorlizarraga - Responder
No doubt - this is the art of teardown we want to see!!
Now the only question is: How long it will take to the teardown of the Millenium Falcon?!? And how is Han about it?!?
Oliver Ermonis - Responder
I like so much this site... and this saber!!!!
Juan Carlos Allo Navarro - Responder
I've gotten to hold this very lightsaber. It is a piece of art, and the build process was insane. This is one of my favorite sabers he has built.
rudimentz - Responder
Replace the focusing crystal w/ a Dilithium one, can now narrow beam down to micron diameters '-}
Mark Cob - Responder
Hi,
I'm having weird grounding problem with my lightsaber - the plasma beam shows light interference. I think the surge circuit is in ground loop with AC mains as this interference is much more prominent when placed near transformers (Desktop PSU or laptop power brick). I was not able to measure capacitance of the two inverting capacitors from the dilithium cell - their value is likely in kilofarads (both seem to overload my digital multimeter, but there is some sort of voltage difference between the body and negative terminals - upon connecting those to my oscilloscope, I measured 450mV slew at 150Hz with 5% THD+N, so it seems there is a grounding problem between the body and the internal electronics (I'm based in Europe, with 230V 50Hz mains). Any idea where the problem might be, or which components need replacing?
Andrew - Responder
Based on your description, I'd say the culprit is the dilithium cell. Building lightsabers is tricky business, so if you're going to use technology from another universe, you're on your own my friend!
Jeff Suovanen -
Amazing ! give me one of them and I will pay on soon...Okey
erwinwibawa - Responder
this was helpful thank you
anikin slaywalker - Responder
Where to buy it ? :(
laberintodepenumbra - Responder
Why not get one of the make it yourself light sabers from Disney’s Galaxy Edge and tear it down.
rm.marino - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 140
Todo: 122,340
