Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ferramentas utilizadas neste teardown
Introdução
This guide will help you break the W600 keyboard down. You will meet tons of glue in this process.
Do not expect this will help you to repair the keys: they are mounted tightly onto the case and are unable to disassemble.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Lenovo W600 Keyboard, use o nosso manual de serviço.
  1. Take off the protective stickers on the four corners Use a Phillips screwdriver to remove all five screws on the keyboard
    • Take off the protective stickers on the four corners
    • Use a Phillips screwdriver to remove all five screws on the keyboard
    • Insert a word screwdriver into one corner and move around to break all the hot glue. You may need to use steel rulers to break the hot glue between the keys and the backplate.
    • After struggling for a while you should be able to take the backplate off.
  2. Unplug the FPC cable. Use the same method as removing the backplate to break the hot glue between the keys and their backplate.
    • Unplug the FPC cable.
    • Use the same method as removing the backplate to break the hot glue between the keys and their backplate.
    • No more teardown process is possible without breaking the case of the keyboard.
_ Lithane
Membro desde: 18/08/2017
101 Reputação
Autoria de 1 guia
i am experiencing a problem with my levovo w700 laptop keyboard. it is the problem as seen in this youtube vid - https://youtu.be/qmMcfFHCM60
any solutions.
i am using windows 7
Mr Keith S Boyd - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 634
