Ir para o conteúdo principal
Vídeo de Apresentação
Introdução
How to completely disassemble your tablet.
__________Video tutorial:__________
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Lenovo Ideatab A1000, use o nosso manual de serviço.
  1. Unscrew the two Phillips screws under the memory card and the SIM card covers. Use a plastic tool and remove the back cover. Use a plastic tool and remove the back cover.
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Unscrew the 8x screws and remove the mother board cover. Disconnect the battery connector. Disconnect the battery connector.
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Volume Buttons, Power Button and Vibration motor Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector. Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  4. Remove the lower speaker and the microphone. Unstuck the Power button, Volume buttons and Vibration motor from the middle frame. Unhook the LCD Display and the Touch screen flex cables.
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  5. Remove the Logic board. Be careful, the mother board is sticked to the front outer case. Be careful, the mother board is sticked to the front outer case.
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  6. CPU - Mediatek, MT8317ATA Memory chip -  eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410 Power management chip - Mediatek MT6329BA
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
Membro desde: 09/12/2013
178.781 Reputação
315 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
297 Membros
983 Guias de autoria
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - Responder
Thanks for this guide!
Pooshon Banerjee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 13,640
