Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Lenovo IdeaTab S2107A-F Android 7", use o nosso manual de serviço.
  1. Lenovo IdeaTab S2107A-F Teardown, Front and Back Before Opening It Up: passo 1, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Front and Back Before Opening It Up: passo 1, imagem 2 %32
    • Ready to start tearing it apart. It was a cheap tablet several years ago, it's wifi is really slow, so it's not useable these days. Let's see what's inside.
  2. Lenovo IdeaTab S2107A-F Teardown, Remove the Rear Top Cover: passo 2, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Remove the Rear Top Cover: passo 2, imagem 2 %32
    • We're looking at the rear top here. It just slides toward the top of the tablet and lifts off, exposing the camera and micro SD card holder.
  3. Lenovo IdeaTab S2107A-F Teardown, Remove 3 Small Phillips Screws, and One Tiny Phillips Screw: passo 3, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Remove 3 Small Phillips Screws, and One Tiny Phillips Screw: passo 3, imagem 2 %32 Lenovo IdeaTab S2107A-F Teardown, Remove 3 Small Phillips Screws, and One Tiny Phillips Screw: passo 3, imagem 3 %32
    • A number 0 phillips screw driver works for all of these screws, and all steps going forward.
  4. Lenovo IdeaTab S2107A-F Teardown, A Picture of the Holes of the Small and Tiny Empty Screws: passo 4, imagem 1 %32
    • Insert wisdom here.
  5. Lenovo IdeaTab S2107A-F Teardown, Find the Hidden Phillips Screw, and Remove It: passo 5, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Find the Hidden Phillips Screw, and Remove It: passo 5, imagem 2 %32 Lenovo IdeaTab S2107A-F Teardown, Find the Hidden Phillips Screw, and Remove It: passo 5, imagem 3 %32
    • The rear cover wouldn't pull off, even when prying with my "spudger". I didn't want to break the tablet (yet). Then I noticed the round white spot. I scraped away the brittle white paint, exposing another phillips screw, and removed it. (There goes my warranty! They made it tamper evident.)
  6. Lenovo IdeaTab S2107A-F Teardown, Small and Tiny Screws Removed: passo 6, imagem 1 %32
    • Total 5 so far, 1 tiny, 4 small
  7. Lenovo IdeaTab S2107A-F Teardown, Slide the Main Rear Cover Off: passo 7, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Slide the Main Rear Cover Off: passo 7, imagem 2 %32
    • With the hidden screw removed, the rear cover easily slides off. Push it towards the bottom of the tablet with your thumbs. It moves 1/4 inch and stops, shown in the second picture. Then it is freely lifted off the back.
    • Sorry for the blurry pictures. My photos get sharper as we go along. Really
  8. Lenovo IdeaTab S2107A-F Teardown, Battery and Speakers Are Exposed: passo 8, imagem 1 %32
    • Stero speakers are at the tablet's bottom. The 3.7 VDC Lithium Polymer battery is right there. 13.7 Wh / 3700 mAh. Fairly large for a cheap tablet. It adds to the heft of this tablet.
  9. Lenovo IdeaTab S2107A-F Teardown, Battery is Glued In.  And Appears Hard-Wired In.: passo 9, imagem 1 %32
    • I pried the battery up slowly, it's sticky rubber type glue, but it was a warm day, so it came loose with some patience. (I don't have a proper spudger, a plastic picnic knife had to do instead.)
  10. Lenovo IdeaTab S2107A-F Teardown, Lots More Phillips Screws to Remove: passo 10, imagem 1 %32
    • With the main back cover off, there are lots of phillips screws scattered around the case, surrounding the battery. I counted 10 more screws.
    • 1 at the tablet's top above the battery, 3 across (2 small and 1 tiny), 2 across at the midpoint of the battery, 2 across, and 2 across below the battery at the tablet's bottom.
  11. Lenovo IdeaTab S2107A-F Teardown, I Tried Prying the Inside Case Apart: passo 11, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, I Tried Prying the Inside Case Apart: passo 11, imagem 2 %32 Lenovo IdeaTab S2107A-F Teardown, I Tried Prying the Inside Case Apart: passo 11, imagem 3 %32
    • With all those screws out, I tried prying it apart to expose the motherboard, but it would come all the way off. There's something still holding it together . . .
  12. Lenovo IdeaTab S2107A-F Teardown, Another Hidden Screw: passo 12, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Another Hidden Screw: passo 12, imagem 2 %32 Lenovo IdeaTab S2107A-F Teardown, Another Hidden Screw: passo 12, imagem 3 %32
    • Something was holding it together at the tablet's top. So, I pealed away the innocent looking serial number sticker, and there it was. One more phillips screw. With that gone, the plastic inside cover lifted off easily. It's apart, and there's the motherboard.
  13. Lenovo IdeaTab S2107A-F Teardown, Removing the Battery Wires: passo 13, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Removing the Battery Wires: passo 13, imagem 2 %32
    • The battery has 5 wires, 2 red hot wire, 2 black ground, and 1 white. I assume the white is used by the cpu to monitor charging? battery temperature?
    • I measured 3.9 VDC red-black on battery power, and 4.1 VDC when the battery was charging through its USB port.
    • And 3.9 VDC red-white on battery power, 2.7 VDC when charging. While white-black was 0.0 VDC on battery, and 1.3 VDC when charging.
  14. Lenovo IdeaTab S2107A-F Teardown, Battery Wires Pried Up Easily: passo 14, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Battery Wires Pried Up Easily: passo 14, imagem 2 %32
    • With the glue loose, and the wires removed, the battery is available as a spare for me.
  15. Lenovo IdeaTab S2107A-F Teardown, Small Devices: passo 15, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Small Devices: passo 15, imagem 2 %32 Lenovo IdeaTab S2107A-F Teardown, Small Devices: passo 15, imagem 3 %32
    • The rear camera has a short cable that pries off easily.
    • The haptic motor sits on the side of the tablet. I used it with the on-screen keyboard to help me when typing on the tablet
    • The microphone is on the other side of the tablet, also easily removeable.
  16. Lenovo IdeaTab S2107A-F Teardown, Remove Motherboard: passo 16, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Remove Motherboard: passo 16, imagem 2 %32
    • There's one phillips screw in the middle of the motherboard, near to where the battery was. Remove that and then the circuit board pries apart. It's a tight fit, but with the screw removed it's just a friction fit.
    • And there it is flopped over on it's back, still attached by ribbon cables.
  17. Lenovo IdeaTab S2107A-F Teardown, Motherboard and CPU: passo 17, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Motherboard and CPU: passo 17, imagem 2 %32
    • Mediatek CPU
  18. Lenovo IdeaTab S2107A-F Teardown, Pry Loose the Ribbon Cables: passo 18, imagem 1 %32 Lenovo IdeaTab S2107A-F Teardown, Pry Loose the Ribbon Cables: passo 18, imagem 2 %32 Lenovo IdeaTab S2107A-F Teardown, Pry Loose the Ribbon Cables: passo 18, imagem 3 %32
    • Video and Touch Screen cables, I assume.
  19. Lenovo IdeaTab S2107A-F Teardown, Remove the Screen?  Not Without Breakage: passo 19, imagem 1 %32
    • The tablet's screen is tightly held in the plastic case. I tried prying it apart, but didn't want to crack it. You can see the metal backing, this screen is heavy with all that metal. I stopped here so that I wouldn't break the glass on the front.
    • I really wanted to see if the screen was usable in a future project. But the ribbon cable connections looked proprietary, so I'm not hopeful.
Allen
Membro desde: 01/02/18
1.485 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 641
