Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua LG VX8350 Repair, use o nosso manual de serviço.
  1. LG VX8350 Teardown, Battery: passo 1, imagem 1 %32 LG VX8350 Teardown, Battery: passo 1, imagem 2 %32
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. LG VX8350 Teardown: passo 2, imagem 1 %32 LG VX8350 Teardown: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. LG VX8350 Teardown, Circuit Board Housing: passo 3, imagem 1 %32 LG VX8350 Teardown, Circuit Board Housing: passo 3, imagem 2 %32 LG VX8350 Teardown, Circuit Board Housing: passo 3, imagem 3 %32
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. LG VX8350 Teardown: passo 4, imagem 1 %32 LG VX8350 Teardown: passo 4, imagem 2 %32
    • Lift the back cover starting at the bottom of the phone.
  5. LG VX8350 Teardown: passo 5, imagem 1 %32 LG VX8350 Teardown: passo 5, imagem 2 %32
    • Remove the back cover completely from the phone.
  6. LG VX8350 Teardown, Circuit Board: passo 6, imagem 1 %32
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. LG VX8350 Teardown: passo 7, imagem 1 %32 LG VX8350 Teardown: passo 7, imagem 2 %32
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  8. LG VX8350 Teardown, Keypad: passo 8, imagem 1 %32 LG VX8350 Teardown, Keypad: passo 8, imagem 2 %32
    • Lift the keyboard and remove it from the phone.
  9. LG VX8350 Teardown, Screen Cover: passo 9, imagem 1 %32 LG VX8350 Teardown, Screen Cover: passo 9, imagem 2 %32 LG VX8350 Teardown, Screen Cover: passo 9, imagem 3 %32
    • Locate the two rubber circles covering the screws.
    • Remove the rubber covers using tweezers.
    • Using the Phillips head screwdriver, unscrew and remove the two screws.
  10. LG VX8350 Teardown: passo 10, imagem 1 %32 LG VX8350 Teardown: passo 10, imagem 2 %32 LG VX8350 Teardown: passo 10, imagem 3 %32
    • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
    • Take care not to do this with too much force, as it could crack the cover.
    • Completely remove the cover from the phone.
  11. LG VX8350 Teardown, LG VX8350 Teardown: passo 11, imagem 1 %32
    • You have now performed a complete teardown of the LG VX8350.
Jonathan Flowers
Membro desde: 10/18/13
607 Reputação
Autoria de 6 guias
Equipe
Clemson, Team 14-7, Benson Fall 2013 Membro de Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 1,517
