Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua LG T310, use o nosso manual de serviço.
  1. LG T310 Teardown, LG T310 Teardown: passo 1, imagem 1 %32
    • Slide back cover down with hand in the direction of the arrow on the cover
    • Gently remove back cover
    • Remove the battery by inserting the plastic opening tool into the groove and gently prying it out
  2. LG T310 Teardown: passo 2, imagem 1 %32 LG T310 Teardown: passo 2, imagem 2 %32
    • Remove all of the screws on the back of the phone using a Phillips head screw driver
    • Slide out the SIM card from the phone
  3. LG T310 Teardown: passo 3, imagem 1 %32
    • Using the plastic opening tool, pry off the shell of the phone, revealing the motherboard
  4. LG T310 Teardown: passo 4, imagem 1 %32 LG T310 Teardown: passo 4, imagem 2 %32
    • Using the plastic opening tool, gently pry the motherboard out (while doing this be sure not to pull on the mother board as it is attached to the touch screen)
    • Starting at the top left corner of the screen (with phone face down), insert your plastic opening tool and work down the left side.
    • The screen should be loose now making it possible to remove it from the case by hand (try not to touch the actual screen, only the side or back).
    • This completes the tear down of your LG-T310 Cookie
Andrew
Membro desde: 11/07/13
116 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,356
