I have tried to include as much detail as possible in this teardown. I have even inspected the chips on the mainboard! Thanks for looking, and I hope you find this useful.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua LG GW300, use o nosso manual de serviço .
Get a thin opening tool and slide it around the bezel of the device.
Make sure you put it in the correct place, behind the silver bezel of the front of the phone!
The front and back of the device should separate.
Two buttons should come off after you have removed the back.
This is the rear speaker.
Both of these buttons need to be pried from the front casing to allow the mainboard to come away from the front housing.
These buttons are soldered to the mainboard so make sure you don't break them!
The front speaker also has to be pried from the front housing.
The LCD ribbon cable and connector are under a plastic sheet that has to be removed.
The ribbon cable can then be take out of the connector
The ribbon connector is very fragile, so be careful when lifting the lever.
Incorporar este guia
Escolha um tamanho e copie o código abaixo para incorporar este guia como um pequeno widget no seu site / fórum.
Passo único
Guia completo
Pequeno - 600px
Médio - 800px
Grande - 1200px
Pré-Visualização
