Introdução
This is a simple teardown of the LG G watch R.
O que você precisa
First remove the watch band using a small flat screw driver to compress the spring loaded pin.
Remove the four T4 torx screws (Green).
Carefully pry the base off using a thin flat screw driver
Disconnect the four electrical connectors from the board
Orange - Battery connector
Blue - button and charging connector
Green - Backlight
Purple - O-LED Controller + Mic
Remove the three phillips screws securing the board down. Then lift the board off the base
The battery is below the board.
The battery can easily be pried out using a small flat head screwdriver.
Using a small pliers and a small flat screwdriver the battery housing comes out easily.
Pictures of the front and back of the 1.3" P-OLED.
The screen is glued in.
8 comentários
Is there a wifi antenna inside the LG G watch R?
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Are there differences between the UK as US G Watch R?
hi, have you found a solution? on my watch everything works except the touch screen….when you touch it or move your arm it turns off….if you put your palm on the screen istead of turning off it goes on
Ha lezárt a kijelző de nem tudom a kódot lehet valamit tenni?? :(
