Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Kyocera Oystr, use o nosso manual de serviço.
  1. Kyocera Oystr Teardown, Removing the battery: passo 1, imagem 1 %32 Kyocera Oystr Teardown, Removing the battery: passo 1, imagem 2 %32 Kyocera Oystr Teardown, Removing the battery: passo 1, imagem 3 %32
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: passo 2, imagem 1 %32 Kyocera Oystr Teardown, Removing screws from screen: passo 2, imagem 2 %32 Kyocera Oystr Teardown, Removing screws from screen: passo 2, imagem 3 %32
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: passo 3, imagem 1 %32 Kyocera Oystr Teardown, Exposing internal components: passo 3, imagem 2 %32 Kyocera Oystr Teardown, Exposing internal components: passo 3, imagem 3 %32
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: passo 4, imagem 1 %32
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: passo 5, imagem 1 %32 Kyocera Oystr Teardown, Screen removal: passo 5, imagem 2 %32 Kyocera Oystr Teardown, Screen removal: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: passo 6, imagem 1 %32
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
Membro desde: 10/04/11
24 Reputação
Autoria de 2 guias
Equipe
UW Stout, Team 5-7, Zhou Fall 2011 Membro de UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
Membros da 2
Autoria de 4 guias
2 comentários
where do I get a new screen?
LARS ANDERSEN - Responder
where do i get a new screen
thanks
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 4,362
