Introdução
This guide provides information on dissembling the Kyocera Oystr phone to allow for repairs.
O que você precisa
Make sure the phone is turned off before disassembly.
Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
Remove the battery from the casing. This is simply a precaution.
Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
Lift the plastic cover of the phone screen upwards with a plastic opening tool.
Remove the two screws from the metal cover.
Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
Use your fingernail to detach the ribbon connecting the board to the screen.
Remove the damaged screen from the device.
Follow these steps in reverse order to replace Kyocera Oystr’s screen.
2 comentários
where do I get a new screen?
where do i get a new screen
thanks
