O que você precisa
This guide does not show the disassemble of the clearomizer (highlighted in the picture), as in more recent versions it is monolithic and can't be disassembled, and focuses on the cigarette body.
Remove the four screws holding the plastic covers to the metal frame:
Two Torx T4 screws on the top of the cigarette body, near the clearomizer plug
Two Torx T4 screws on the bottom of the cigarette body, near the USB port
Remove the bottom lid with a plastic spudger
Remove the top plastic lid with a plastic spudger. If it is stuck, due to debris, mount the clearomizer lower part and use it to pull the top cover.
Time to remove the front panel:
Insert a plastic spudger in the top part and start lifting it
Continue removing the front plate with a plastic opening pick
The frontal button should fall outside, as it is only laid inside the specific hole, not glued. If it is stuck, use a pair of ESD tweezers to remove it.
Extract the board and the battery, using a tweezer to pull the top of the board and/or pushing gently the lower part of the battery, with a round plastic spudger.
The battery is protected by three foam pads, the side one is glued both to the battery and to the board
The battery is a 14500 lithium battery. This one in particular is made by EVE, nominally it has a 3.7V voltage, has a 900 Mah capacity and can supply 3.33 Wh.
3 comentários
Hi,
I tried cleaning Q16 FF, and since then, it only shows blinking lights whenever powered up. This occurs regardless of whether the tank is plugged in or not. The battery is charged. Is there anything I can do about this?
How did you clean it? Did you use water or another conductive liquid?
كيف احصل علي سلك حراري يعمل من الموجود بها
