Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Humax IRHD 5000C, use o nosso manual de serviço.
  1. Humax IRHD 5000C Teardown, open up case: passo 1, imagem 1 %32 Humax IRHD 5000C Teardown, open up case: passo 1, imagem 2 %32
    • Unscrew the screws on the outside.
    • Slide the top cover a bit to the back, and lift it from the enclosure.
  2. Humax IRHD 5000C Teardown, remove power supply: passo 2, imagem 1 %32 Humax IRHD 5000C Teardown, remove power supply: passo 2, imagem 2 %32
    • Remove the various pieces holding in the power supply.
    • Remove power cable (already cut of in the photo).
    • Unscrew screws.
    • Disconnect mainboard cables.
    • Remove the power supply from the enclosure.
  3. Humax IRHD 5000C Teardown, remove front: passo 3, imagem 1 %32 Humax IRHD 5000C Teardown, remove front: passo 3, imagem 2 %32
    • Disconnect the cables connecting the mainboard to the front panel.
    • With a flathead screwdriver, unclip the 2 topside clips, and 3 clips on the bottom of the enclosure, and the front will detach.
  4. Humax IRHD 5000C Teardown, disassemble front: passo 4, imagem 1 %32 Humax IRHD 5000C Teardown, disassemble front: passo 4, imagem 2 %32 Humax IRHD 5000C Teardown, disassemble front: passo 4, imagem 3 %32
    • Unclip the 4 clips from left to right, and remove the panel.
    • With the pliers, clamp the white connector and push it through.
  5. Humax IRHD 5000C Teardown, remove mainboard: passo 5, imagem 1 %32 Humax IRHD 5000C Teardown, remove mainboard: passo 5, imagem 2 %32
    • Unscrew the screws and remove the mainboard from the case.
knipwim
Membro desde: 09/01/18
8.527 Reputação
Autoria de 30 guias
2 comentários
What are those unsoldered pad connectors for? A hard drive?
Jessica Parnelli Fawkes - Responder
Don’t know, could be a SCSI drive, there are 68 pins. I included a detail picture in the last step.
knipwim -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 1,443
