Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Huawei Mate 20 X 5G, use o nosso manual de serviço.
  1. Huawei Mate 20 X 5G Teardown, Huawei Mate 20 X 5G Teardown: passo 1, imagem 1 %32 Huawei Mate 20 X 5G Teardown, Huawei Mate 20 X 5G Teardown: passo 1, imagem 2 %32 Huawei Mate 20 X 5G Teardown, Huawei Mate 20 X 5G Teardown: passo 1, imagem 3 %32
    • Here's the lowdown on this Mate 20 X 5G:
    • 7.2" OLED multitouch display with 1080 × 2244 resolution
    • Octa-core Huawei Kirin 980 chipset, paired with 8 GB RAM
    • 256 GB onboard storage
    • Balong 5000 multi-mode 5G modem
    • 4,200 mAh battery with 40 W SuperCharge 2.0 support
    • Triple rear cameras: 40 MP ƒ/1.8, 20 MP ƒ/2.2, and 8 MP ƒ/2.4 lens with 5x optical zoom
    • The front-facing camera resides in a "waterdrop" notch, and the rear protective cover comes with a neat reminder which we will dutifully ignore.
  2. Huawei Mate 20 X 5G Teardown: passo 2, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 2, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 2, imagem 3 %32
    • On the bottom we recognize the usual suspects: a USB-C port, two microphone holes and a speaker grille.
    • Along the top edge, we find another microphone hole, the infrared blaster, and the barest sliver of a grille for the earpiece speaker.
    • Compared to the already-large Mate 20 Pro, the X 5G looks colossal. On its backside, we note the 5G branding, and the fingerprint sensor underneath its array of cameras.
  3. Huawei Mate 20 X 5G Teardown: passo 3, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 3, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Suction Handle
    $2.99
    Comprar
    • Though this Mate is only rated IP53, the SIM card tray is equipped with a rubber gasket—something we usually see on "waterproof" smartphones these days.
    • Slot 1 of this SIM tray is reserved for 5G cards, whereas slot 2 only accepts up to 4G cards.
    • To our surprise, we get the glued-down back cover off lickety-split—no heat required! A suction handle and a halberd spudger separates everything nicely.
    • Adhesives can harden with age, so maybe next time won't be so easy—but our fresh-from-the-factory unit was very cooperative.
    • A generously proportioned fingerprint flex cable keeps the back cover tethered for now, but it's such a long leash that we don't mind. On to the next layer.
  4. Huawei Mate 20 X 5G Teardown: passo 4, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 4, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 4, imagem 3 %32
    • A flock of screws hold the NFC coil, antenna, and graphite heat conductor pad in place. One hides behind a tamper-proof sticker, and another one lurks under the camera flash module—a strange place for a screw.
    • With those bits out of the way, we can finally disconnect the fingerprint sensor and get our first good look inside this phone.
  5. Huawei Mate 20 X 5G Teardown: passo 5, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 5, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 5, imagem 3 %32
    • The 24 MP, ƒ/2.0 front-facing peeper comes out with a simple pry. We'll never grow tired of these repair-friendly press-fit connectors.
    • The motherboard also comes out easily, allowing us to unplug the three-eyed rear camera block from the back.
    • This triclops carries the same tech as the Mate 20 Pro from October 2018—a 40 MP ƒ/1.8 wide angle, a 20 MP ƒ/2.2 ultra wide angle, and an 8 MP ƒ/2.4 telephoto lens.
  6. Huawei Mate 20 X 5G Teardown: passo 6, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 6, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 6, imagem 3 %32
    • Finally, we get to the nitty-gritty of this Mate's iteration—the motherboard:
    • Micron D9WGR (MT53D1G64D8NZ-046 WT:E) 8 GB LPDDR4 with Kirin 980 SoC layered underneath
    • Toshiba THGAF8T1T83BAIR 256 GB NAND flash
    • Samsung K4UHE3D4AA-CGCJ 3 GB LPDDR4X—more on that later
    • Skyworks 78191-11 low-band front-end module for WCDMA/LTE
    • HiSilicon Hi6526 PMU
    • NXP 80T37 (likely NFC controller)
    • For comparison, the smaller board on the lower left belongs to the Mate 20 Pro.
  7. Huawei Mate 20 X 5G Teardown: passo 7, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 7, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 7, imagem 3 %32
    • … more on the other side of the board:
    • Qorvo 77031 4T8R mid/high-band module
    • HiSilicon Hi63650
    • HiSilicon Hi6421 power management IC
    • HiSilicon Hi1103 Wi-Fi module
    • HiSilicon Hi6D03
    • And again the smaller Mate 20 Pro motherboard for comparison.
  8. Huawei Mate 20 X 5G Teardown: passo 8, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 8, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 8, imagem 3 %32
    Hot Air Rework Station Hakko FR-810B-05
    $919.99
    Comprar
    • Notably absent from our initial chip findings is the Balong 5000, HiSilicon's multi-mode networking chipset that is supposed to be the powerhouse of this 5G cell.
    • On a hunch, we coarsely chisel off the extra Samsung LPDDR4X chip to find …
    • HiSilicon Hi9500 GFCV101! This is most likely the Balong 5000 we're looking for.
    • Just to be sure, we pry up the Micron memory chip as well. Sure enough, underneath slumbers the HiSilicon Hi3680 GFCV150, also known as Kirin 980.
    • Our hot air station had the day off. Deal with it.
    • It looks like the 5G modem comes bundled with its own block of dedicated LPDDR4X memory—a whopping 3 GB of it, if we've decoded those Samsung package markings correctly. Is that a giant data buffer? This is the first 5G modem we've seen in the wild, so sound off in the comments if you know more than we do.
  9. Huawei Mate 20 X 5G Teardown: passo 9, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 9, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 9, imagem 3 %32
    • To get unobstructed access to the battery, we remove the board interconnect cable.
    • While we're at it, we also pry up the glued-in loudspeaker ...
    • … and the tiny daughterboard with the USB-C port soldered onto it.
  10. Huawei Mate 20 X 5G Teardown: passo 10, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 10, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 10, imagem 3 %32
    • We're always happy to see built-in battery removal instructions, and follow them step-by-step. It's as easy as 1-2-3!
    • Though we didn't need heat this time around, we are still rewarded with a clean battery extraction.
    • This is the exact same battery used in the Mate 20 Pro, weighing in at 16.04 Wh (4,200 mAh @ 3.82 V).
    • That's well short of the whopping 19.1 Wh (5,000 mAh) battery in the standard Mate 20 X—but it's still a monster compared to the iPhone XS Max's dual-cell, 12.08 Wh (3,179 mAh) powerplant.
  11. Huawei Mate 20 X 5G Teardown: passo 11, imagem 1 %32 Huawei Mate 20 X 5G Teardown: passo 11, imagem 2 %32 Huawei Mate 20 X 5G Teardown: passo 11, imagem 3 %32
    Halberd Spudger
    $2.99
    Comprar
    • The display adhesive holds on a bit tighter than the back cover adhesive, but gives way after some heat and skilled halberd slicing.
    • This Mate doesn't have any fancy under-display fingerprint sensor. There's just a blank OLED screen and the aluminum frame.
    • This 7.2 inch OLED panel is manufactured by Samsung.
    • Much like in the standard Mate 20 X, there's a big vapor chamber hiding on the aluminum frame behind the graphite foil.
  12. Huawei Mate 20 X 5G Teardown: passo 12, imagem 1 %32
    • With all the parts more or less gently removed, we have an overview of Huawei’s foray into the mobile 5G sector.
    • Except for three "US"-manufactured chips (Micron, Skyworks and Qorvo) and a dutch NXP module, the motherboard's major sockets are dominated by Huawei's in-house brand HiSilicon and other Asian manufacturers (Toshiba, Samsung).
    • Want to see future smartphone guts from Huawei? Subscribe to our newsletter and stay in the loop.
  13. Considerações finais
    • Many components are modular and can be replaced independently.
    • The battery is accessible after removing the rear cover and midframe, and is equipped with pull tabs.
    • Standard Phillips screws are used along with an average amount of adhesive.
    • The midframe covers the battery and fingerprint sensor connectors, and is itself obstructed by the camera sensors and flash.
    • Glued-down front and back glass means greater risk of breakage, while making all repairs difficult to start.
    • Screen repairs will require near-complete disassembly.
    Índice de reparabilidade
    4
    Reparabilidade 4 de 10
    (10 é o mais fácil de reparar)
Tobias Isakeit
Membro desde: 03/31/14
117.720 Reputação
Autoria de 188 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.539 guias
10 comentários
OOO first comment! By the way, Are Mate 20 X and Mate 20 X 5G screens cross compatible? They both have the same dimensions so I am intrested
Dinan Blueje - Responder
By the looks and the make of both phones the displays should be compatible. We haven’t checked yet since we don’t have a Mate 20 X at hand. Check a users teardown of the Mate 20 X here.
Tobias Isakeit -
What are the 5G rf chain components?
nevod_m - Responder
Is there a mm wave antenna module in this phone? How is 5G mm wave working without an antenna module like the one Qualcomm has?
Vin - Responder
Hi, Is It Possible to Fully Remove the Fingerprint Sensor from the Back Cover? I will buy another back cover, because my broke ..
felipe_carvalho1997 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 42
Últimos 30 dias: 156
Duração total: 42,895
