Introdução
The Honeywell RWD41 Water Defense Water Sensing Alarm (available on Amazon) sounds an alarm when its sensing cable is submerged in water. This product detects water leaks early and saves homeowners costly water damage repair bills.
O que você precisa
The Honeywell Water Sensing Alarm has three components:
Sensing Cable
Extension Cable
Base Station
Disconnect the RJ-11 jack that connects the base station to the extension cable.
Disconnect the RJ-11 jack that connects the extension cable to the sensing cable.
Pop open the battery case with a fingernail and carefully remove the 9V battery without breaking the 9V battery connector still attached to the battery
Disconnect the 9V battery connector from the battery
Unscrew the 4 screws holding the plastic enclosure together with the Phillips #1 Screwdriver
The circuit board slides off of plastic standoffs for closer inspection
The circuit board has three notable components
Microchip PIC12F510 8-bit microcontroller
Piezoelectric buzzer for water alert
RJ-11 Connector
The Microcontroller provides a signal for the speaker and interprets the signal coming in from the RJ-11 connector.
The Microcontroller runs off 2.0-5.5V (from datasheet here) so the board also regulates the battery 9V down to a voltage usable by the microcontroller.
