Ir para o conteúdo principal
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Honeywell Pull Station Fire Alarm, use o nosso manual de serviço.
  1. Honeywell Pull Station Fire Alarm Teardown, Testing: passo 1, imagem 1 %32
    • With it unplugged, set it on a flat surface like a stone.
    • This will make sure your pull station is level, making possible repair easier.
    • Pull down the pull station until there is a yellow tag saying "ACTIVATED." Then proceed to say "beep" 3 times.
    • Try not to pull it too hard and also make sure you do not directly spit into the station.
  2. Honeywell Pull Station Fire Alarm Teardown, Hammering Time!: passo 2, imagem 1 %32 Honeywell Pull Station Fire Alarm Teardown, Hammering Time!: passo 2, imagem 2 %32
    • Proceed to hit the pull station with a hammer also hitting the stone, making sure that the parts inside come out swiftly.
    • Do not try to drag it too much or else scratches will appear.
    • Pull down the station again multiple times to no avail.
    • A possible maneuver is taking a hard blow for the center, aiming your best shot, to literally "explode" the device and cause the parts to go everywhere.
  3. Honeywell Pull Station Fire Alarm Teardown, Center Blow: passo 3, imagem 1 %32
    • With your best shot, take a center blow at the pull station to cause the device to explode and parts to go everywhere.
    • Do it incorrectly and you risk several severe injuries.
  4. Honeywell Pull Station Fire Alarm Teardown, Final Thoughts: passo 4, imagem 1 %32
    • Repairability Score: 1 out of 10 (10 is easiest to repair
    • The teardown has several useful parts you can replace.
    • After the hammering and center blow, you have essentially destroyed the device making repair useless.
    • Go buy a new pull station
Gabi Salinas
Membro desde: 11/07/21
2 Reputação
Autoria de 1 guia
2 comentários
instructions unclear, the pull station is now hitting me with a hammer. 0/10 wouldn't recommend to anyone
techtalk11 - Responder
Amazing tear down. I actually wondered what these look like inside. The shards did hit my neighbors dog though.
Corbanizer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 683
