Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Home Essentials Sandwich Press, use o nosso manual de serviço.
  1. Home Essentials Sandwich Press Teardown, Home Essentials Sandwich Press Teardown: passo 1, imagem 1 %32 Home Essentials Sandwich Press Teardown, Home Essentials Sandwich Press Teardown: passo 1, imagem 2 %32
    • Unscrew the 10mm screws securing the plastic handle cover using a size PH1 screwdriver.
    • These screws are very loose and easy to remove.
  2. Home Essentials Sandwich Press Teardown: passo 2, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 2, imagem 2 %32 Home Essentials Sandwich Press Teardown: passo 2, imagem 3 %32
    • Unscrew the metal hot plates from the plastic covering using a size PH1 screwdriver.
    • The screws are 12 mm long.
  3. Home Essentials Sandwich Press Teardown: passo 3, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 3, imagem 2 %32 Home Essentials Sandwich Press Teardown: passo 3, imagem 3 %32
    • Unscrew the plastic handle cover using a Special Key Tri-wing.
    • One screw was very hard to unscrew, so grip paste had to be used.
    • The screws are 9 mm long.
  4. Home Essentials Sandwich Press Teardown: passo 4, imagem 1 %32
    • Remove the plug-in cord caps using a pair of pliers.
    • The metal caps have to be bent a bit to remove the plug-in cord caps, which means the metal caps will not work anymore.
  5. Home Essentials Sandwich Press Teardown: passo 5, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 5, imagem 2 %32 Home Essentials Sandwich Press Teardown: passo 5, imagem 3 %32
    • Now the metal plates are loose from the plastic cover. The plates need to be moved until the end of their hinge slots to slide them apart.
    • The hinges are very easy to take apart, once it is loose from the plastic cover.
  6. Home Essentials Sandwich Press Teardown: passo 6, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 6, imagem 2 %32 Home Essentials Sandwich Press Teardown: passo 6, imagem 3 %32
    • Separate the snap fit and remove the light covers.
    • Remove the cords of the lights by pulling them out of their snap fit.
    • Remove the light covers by pushing them out of the plastic cover.
    • The lights are being taken out very easily with not much pressure.
  7. Home Essentials Sandwich Press Teardown: passo 7, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 7, imagem 2 %32
    • Remove the press latch by using a screwdriver; add some pressure to it to get the latch loose.
    • Removing the press latch is hard and requires extra effort.
  8. Home Essentials Sandwich Press Teardown: passo 8, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 8, imagem 2 %32 Home Essentials Sandwich Press Teardown: passo 8, imagem 3 %32
    • Unscrew the heating element covers using a size PH1 screwdriver.
    • Remove the heating element covers from the plates.
    • The screws are 5 mm long.
  9. Home Essentials Sandwich Press Teardown: passo 9, imagem 1 %32 Home Essentials Sandwich Press Teardown: passo 9, imagem 2 %32 Home Essentials Sandwich Press Teardown: passo 9, imagem 3 %32
    • Unscrew the heating element wires from the hot plates using a PH1 screwdriver. The screws are 5 mm long.
    • Remove the heating elements using a Phillips head screwdriver, and put this screwdriver under the heating elements.
    • Removing the heating elements requires some more pressure because they are put in with a tight snap fit. The heating element will also deform when removed.
Anna Stapor
Membro desde: 03/07/18
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 685
