Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua HTC Evo 3D, use o nosso manual de serviço.
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: passo 1, imagem 1 %32
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: passo 2, imagem 1 %32
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: passo 3, imagem 1 %32
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: passo 4, imagem 1 %32 HTC Evo 3D Teardown: passo 4, imagem 2 %32 HTC Evo 3D Teardown: passo 4, imagem 3 %32
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: passo 5, imagem 1 %32 HTC Evo 3D Teardown: passo 5, imagem 2 %32
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: passo 6, imagem 1 %32
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: passo 7, imagem 1 %32
    • This concludes the (simple) teardown of the Evo 3D.
_Z_
Membro desde: 03/18/12
9.695 Reputação
Autoria de 2 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 327
Autoria de 1.697 guias
Um comentário
Thanks. This was very helpful.
dano706 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 19,543
