Introdução
Hi everyone, here I am with a new guide (teardown/replacement)
Again, you will find little mistakes in my english, but as you know my native language is dutch ...
I hope you will like the guide.
Good luck!
O que você precisa
Remove the 2 panels and the battery at the bottom of the laptop.
After removing these panels, you'll see the RAM, HDD, and Wi-Fi module.
Remove the DVD drive bay by prying a little spudger between the case and the drive cover. Then gently pull it out.
Next, we will remove the screws from the rest of the case.
Start by removing the screws hidden in the battery compartment (M2.5x3).
Now remove the 10 remaining case screws (M2.5x6.5).
There are 2 hidden screws in the HDD compartment (see last picture).
After removing all the screws, we can remove the keyboard.
Use a spudger to pry and search for the "locks"
use your hand to gently remove the keyboard. You will here clicks.
open the socket by clicking it up. pull the connector gently away from the socket.
after removing all the cables/ wires and screws, we can remove the screws from the screen hinges.
after removing the screws from the hinges, put the entire screen apart.
we will remove the motherboard first. see picture 3. you can remove the motherboard by pulling it up and sliding it to the right.
after removing the case. this is the screen internal.
above you will see the camera, the wifi antenna's . under you'll see the hinges and at the left the lcd connector.
you can remove the grey plastic caps by removing the screw(s), under the plastic cap you will find the cables running trough..
you do the same thing at the other side.
At the second picture you see the wires after removing the plastic grey cap. if you have problems with screen failure ( like a black screen or bad connection) its best to check this cable first before buying a new one. The wires are sliding to the cap and sometimes they get cut.
Now the last steps.. we will put some new coolpaste to the soldered CPU and GPU
first remove the 4 screws of the cooling socket.
remove the socket, be carefull for the little power socket attached at the motherboard, running to the cooling fan.
and than put some drop of cooling paste on the CPU/GPU
13 outras pessoas executaram este guia.
16 comentários
Would it be beneficial to remove old CPU and GPU thermal paste?
Show reverse for HP56 Cq notebook
Please put together cq 56 notebookPc
Great instructions thank you!
I reassembled mine but now I cannot turn on the WiFi via the function button.
Everything else works.
I checked the two antenna cable are attached to the correct ones but still cannot turn on WiFi. Any suggestions appreciated
Tanks Santhosh ,
There is a possibility that the noise is comming from broken or loose plastic from the frame of the laptop. Check te frame on broken/ misshapen pieces of plastic.
is there a loose cable ( maybe the cable of the fan itself)? paste the fan cable to the main board.
I should check the fan on broken or misshapen plastic parts , then check the connector and the cable.. try another fan.
Kind regards
Weird.. a noisy fan is mostly due to broken or loose parts. do you have a spare fan?
when you remove the top panel you have to watch out with LCD cables. check the LCD cable , check the LCD connector. sometimes you have to push it back in the connector ( 1 bad connection and it does not work.) Be carefull some LCD cables are easy to tear..., be gently with the connector as well..
Great tutorial!!
I would like to know, in step 13, what is the utility of the cable tagged TSD?
cause my laptop have a backlight problem. I changed the lcd cable but the problem is still there…
next step is to change the whole screen… but I was wondering if the problem could come from the other cable?
thank you!
Woah thank you!
I was’nt expecting an answer so fast! :)
I decided to buy a new screen, so I needed to open the laptop again, and I saw it on the board: MIC WIRE 2PINS
So I guess this is the microphone cable which goes next to the webcam on the top of the screen.
thank you again for your time!
