First of all: my apologies for my english, my native language is Dutch.
So i hope you'll understand my written guide ;)
Have fun!
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua HP G61, use o nosso manual de serviço.
Flip the laptop around and gently remove the keyboard with your fingers.
Start with the corners of the keyboard.
Gently loosen the keyboard with a flat head screwdriver or a thin spudger.
After removing the keyboard, find the other screws located in the grey panel.
Remove the black plastic. Be careful with the white flat cable.
Remove the hinge screws with the screwdriver from the left side to the right side.
Under one of the two hinges, there is a hidden screw (case)
Remove the audio boxes.
Remove all the other wires and cables.
Then gently separate the screen from the case.
Use an iOpener to separate the grey case from the bottom case.
Careful: the battery compartment is together with the grey panel.
Tip: "slide" the iOpener while opening until you hear clicks. It is easy if you slide.
To remove the Processor, unlock the processor socket with a flat screwdriver.
Then gently remove the Processor.
Incorporar este guia
Escolha um tamanho e copie o código abaixo para incorporar este guia como um pequeno widget no seu site / fórum.
Pré-Visualização
