Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua HP G61, use o nosso manual de serviço.
  1. HP G61-430SB Teardown, HP G61-430SB Teardown: passo 1, imagem 1 %32
    • Turn the device over and remove the screws from the battery. Remove the black panels holding the HDD, ram, and wifi.
  2. HP G61-430SB Teardown: passo 2, imagem 1 %32 HP G61-430SB Teardown: passo 2, imagem 2 %32 HP G61-430SB Teardown: passo 2, imagem 3 %32
    • Remove the RAM modules and the HDD as shown in the pictures.
  3. HP G61-430SB Teardown: passo 3, imagem 1 %32 HP G61-430SB Teardown: passo 3, imagem 2 %32
    • Locate the screw for the DVD player and remove it. Then remove the DVD player with a thin spudger.
  4. HP G61-430SB Teardown: passo 4, imagem 1 %32 HP G61-430SB Teardown: passo 4, imagem 2 %32
    • Remove the screws to remove the keyboard.
  5. HP G61-430SB Teardown: passo 5, imagem 1 %32 HP G61-430SB Teardown: passo 5, imagem 2 %32
    • Remove the screws that are circled in the picture. These screws hold the case of the laptop.
  6. HP G61-430SB Teardown: passo 6, imagem 1 %32
    • Remove the WIFI antenna cables from WIFI card.
    • Then remove the screws of the WIFI card and remove the card.
  7. HP G61-430SB Teardown: passo 7, imagem 1 %32 HP G61-430SB Teardown: passo 7, imagem 2 %32
    • Flip the laptop around and gently remove the keyboard with your fingers.
    • Start with the corners of the keyboard.
    • Gently loosen the keyboard with a flat head screwdriver or a thin spudger.
  8. HP G61-430SB Teardown: passo 8, imagem 1 %32 HP G61-430SB Teardown: passo 8, imagem 2 %32
    • After removing the keyboard, find the other screws located in the grey panel.
    • Remove the black plastic. Be careful with the white flat cable.
  9. HP G61-430SB Teardown: passo 9, imagem 1 %32
    • Remove the black flat wire of the LCD screen from the motherboard.
  10. HP G61-430SB Teardown: passo 10, imagem 1 %32
    • Remove the hinge screws with the screwdriver from the left side to the right side.
    • Under one of the two hinges, there is a hidden screw (case)
  11. HP G61-430SB Teardown: passo 11, imagem 1 %32 HP G61-430SB Teardown: passo 11, imagem 2 %32
    • Remove the audio boxes.
    • Remove all the other wires and cables.
    • Then gently separate the screen from the case.
  12. HP G61-430SB Teardown: passo 12, imagem 1 %32 HP G61-430SB Teardown: passo 12, imagem 2 %32
    • Use an iOpener to separate the grey case from the bottom case.
    • Careful: the battery compartment is together with the grey panel.
    • Tip: "slide" the iOpener while opening until you hear clicks. It is easy if you slide.
  13. HP G61-430SB Teardown: passo 13, imagem 1 %32 HP G61-430SB Teardown: passo 13, imagem 2 %32 HP G61-430SB Teardown: passo 13, imagem 3 %32
    • Remove the motherboard by removing the screws first. Be careful with the cables and the wires.
    • Be careful with the connector of the DC power jack. You can replace the USB drivers on that side as well.
  14. HP G61-430SB Teardown: passo 14, imagem 1 %32 HP G61-430SB Teardown: passo 14, imagem 2 %32 HP G61-430SB Teardown: passo 14, imagem 3 %32
    • Remove the cooler.
  15. HP G61-430SB Teardown: passo 15, imagem 1 %32
    • To remove the Processor, unlock the processor socket with a flat screwdriver.
    • Then gently remove the Processor.
Kevin D
Membro desde: 05/02/14
7.343 Reputação
Autoria de 21 guias
2 comentários
Thanks a bunch this helped a whole lot!!!!
Teresa halley - Responder
Thank you very much. Very well explained :)
a.thorne.987 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Duração total: 8,981
