Ferramentas utilizadas neste teardown
A 9 year old Hewlett Packard nx7010 Business Notebook from 2004.
More specifically, its model number is Cnx7010RP745Y580Wcg25P
Back in 2004 it was a mid-range notebook priced at around A$2,000.
1.8GHz Intel Celeron single core CPU.
Windows XP Professional.
1680x1050 Anti-glare Screen (Which had a HORRIFIC ghosting effect).
A tour around the Notebook.
On the left hand side you will find a PCMCIA Card slot and the Optical drive.
On the right hand side you will find an Infra-Red window, Power jack, Kensington Lock and a fan vent.
On the back you will find VGA out, S-Video, 3x USB 2.0 ports, Phone line and Ethernet, Parallel port and FireWire (4 pin).
The display enclosure
It is actually quite easy to do a DIY screen replacement as there is no glass or adhesive to deal with but there are tabs that snap everything together
Removing the 6 screws allows you carefully remove the bezel by carefully undoing the tabs with a flathead screwdriver.
The hinges simply screw on and off
3 comentários
Thanks, I found it most usefull :o)
Thanks! Very interesting. Maybe I clean the fan now. :-)
I didn’t have much luck with step 19, my top cover panel came out with the midframe after unscrewing all visible screws. But thanks anyway.
