Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Graphics Tablet, use o nosso manual de serviço.
  1. Graphics Tablet Stylus Teardown, Pen: passo 1, imagem 1 %32
    • First, carefully pull off the little plastic piece number 1. You must use a knife or something with sharp edge to wedge.
    • After this, you are ready to disassemble pen's exterior case, pulling strongly between parts 3 and 4. If it's hard, you can turn pieces 3 and 4 between them, but only a bit because electronics inside has a guide that lock it into the case.
  2. Graphics Tablet Stylus Teardown: passo 2, imagem 1 %32
    • This is what you are going to find inside. Next step is release primary and secondary buttons (piece nº 2) pulling up straightly and softly, being carefull do not break a and b parts that hold the button.
    • Other piece we must take care is piece number 5, which is quite fragile because is glued to the board through 2 thin wires that could brake. This part keeps wet around the wire and we must dry it perfectly keeping it warm.
    • Point number 6 shows how board engages the pen case. This is why we might no turn too much pieces 3 and 4 between them in step 1 to keep us avoid to break the circuit board.
  3. Graphics Tablet Stylus Teardown: passo 3, imagem 1 %32
    • And here is what's inside a graphic tablet ballpen and what i've broke disassembling.
    • I hope this tutorial helps you, now that you know what's inside a graphic tablet pencil, you'll gess which is your trouble.
pelos
Membro desde: 06/13/10
136 Reputação
Autoria de 1 guia
3 comentários
Awesome, just what I needed! It was driving me nuts trying to get this thing apart. I kind of deduced it needed pulling apart, but didn't quite realize I needed to take that one tab thing off there first. Thanks for the information!
MrsDubin - Responder
Thanks a lot, worked like a charm. To go further about fixing the iron core, see this blog :http://abiyasa.com/blog/2008/04/06/fixin...
Leo Grasset - Responder
i'm glad to be helpfull. :)
pelos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 57
Duração total: 28,191
