This guide explains the teardown of the GPS Garmin Nuvi 200.
The guide shows the parts of the device, and which of those parts are replaceable. Note that Ifixit also provides repair guides for the battery, LCD screen, speaker, and rear casing.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Garmin Nuvi 200, use o nosso manual de serviço .
Top left: back casing
Top right: front casing
Middle left: speaker. Part ($29) and service at portatronics.com
Middle right: motherboard
Bottom left: battery. Part ($5.20) at amazon.com
Bottom right: LCD screen. Assembly kit ($49) at portatronics.com
The Serial Number Strip is at the base of the device. Remove it to two expose two T5 Torx screws.
Using the T5 Torx screwdriver, remove the two T5 Torx screws.
Use care. Do no break apart the strip of orange tape that connects the LCD screen and motherboard (red box in third picture.)
Using the plastic opening tool, only at the bottom of the device, separate the back panel from the front panel.
Use care. The glass on top of the screen is delicate.
Using the plastic opening tool, push apart the clasps holding the LCD screen in place.
Wedge the plastic opening tool between the LCD screen and the metal frame of the device.
Using the Phillips #PH00 screwdriver remove the three screws that hold the motherboard in place.
Use Screwdriver bit #PH00 in IFixIt's Tool Kit to take out the three screws holding the motherboard in place.
Incorporar este guia
Escolha um tamanho e copie o código abaixo para incorporar este guia como um pequeno widget no seu site / fórum.
Passo único
Guia completo
Pequeno - 600px
Médio - 800px
Grande - 1200px
Pré-Visualização
