Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Game Boy Color, use o nosso manual de serviço.
  1. Game Boy Color Teardown, Game Boy Color Teardown: passo 1, imagem 1 %32
    • Take the Game boy and notice the way that it has been injection molded using two tools on the injection molder. The first thing to do is to separate these parts.
  2. Game Boy Color Teardown: passo 2, imagem 1 %32
    • Remove the Game Boys battery case from the back of the game boy and take out any batteries that are inserted. this will leave you with the back panel.
  3. Game Boy Color Teardown: passo 3, imagem 1 %32
    • The Two screws at the top of the back panel can be unscrewed using a Y-triwing screwdriver.
  4. Game Boy Color Teardown: passo 4, imagem 1 %32 Game Boy Color Teardown: passo 4, imagem 2 %32
    • The other small screws in the back panel are very hard to get to you need to drill these out but be careful not to damage the gameboy because this can crack the back panel.
    • You can use a triwing tip instead.
  5. Game Boy Color Teardown: passo 5, imagem 1 %32 Game Boy Color Teardown: passo 5, imagem 2 %32
    • The two panels are snap fitted so you will need to pop them part use something to wedge the crack open.
  6. Game Boy Color Teardown: passo 6, imagem 1 %32 Game Boy Color Teardown: passo 6, imagem 2 %32
    • To remove the main board just remove the 4 screws in the back doing this will mean you can take the board out of the abs plastic sections.
  7. Game Boy Color Teardown: passo 7, imagem 1 %32 Game Boy Color Teardown: passo 7, imagem 2 %32 Game Boy Color Teardown: passo 7, imagem 3 %32
    • The metal cassette holder on the back plastic panel can be removed by simply using a small screw driver in all four corners this should mean it pops off.
  8. Game Boy Color Teardown: passo 8, imagem 1 %32 Game Boy Color Teardown: passo 8, imagem 2 %32
    • The small plastic switch should just fall out of the plastic case make sure not to lose this when opening up the game boy.
  9. Game Boy Color Teardown: passo 9, imagem 1 %32
    • You can simply pull the foam off the back of the screen pulling off the glue try not to tear the foam this makes things easier later.
  10. Game Boy Color Teardown: passo 10, imagem 1 %32 Game Boy Color Teardown: passo 10, imagem 2 %32 Game Boy Color Teardown: passo 10, imagem 3 %32
    • Once the foam is off you can pull the main connection of the screen out this is the brown part of plastic sheeting it simply slides out.
  11. Game Boy Color Teardown: passo 11, imagem 1 %32 Game Boy Color Teardown: passo 11, imagem 2 %32
    • The rubber buttons can easily be pulled off they are not held in but will need a little pull.
  12. Game Boy Color Teardown: passo 12, imagem 1 %32 Game Boy Color Teardown: passo 12, imagem 2 %32 Game Boy Color Teardown: passo 12, imagem 3 %32
    • All the other buttons should just fall out. Be careful not to drop or lose these parts because they will come loose.
  13. Game Boy Color Teardown: passo 13, imagem 1 %32 Game Boy Color Teardown: passo 13, imagem 2 %32 Game Boy Color Teardown: passo 13, imagem 3 %32
    • Pull the screen out of the game boy and take the front panel of plastic away and move it to the side.
  14. Game Boy Color Teardown: passo 14, imagem 1 %32
    • Peel of the protective film on the LCD screen and remove the LCD screen from the casing.
  15. Game Boy Color Teardown: passo 15, imagem 1 %32 Game Boy Color Teardown: passo 15, imagem 2 %32
    • The metal on the screen can be pulled off by getting under it with your fingers this is stuck with a tape.
  16. Game Boy Color Teardown: passo 16, imagem 1 %32 Game Boy Color Teardown: passo 16, imagem 2 %32
    • some parts of the circuit board can also be removed and looked at much closer such as the speakers and the LED lights on the product.
Marcus Broughton
Membro desde: 03/09/10
389 Reputação
Autoria de 1 guia
9 comentários
That feel when everything turns out perfectly. ^.^ Thanks a lot for the guide! I was able to switch out a few broken/worn out bits, and now it's working like new! Super hyped! Thank you so much!
(Also, the screws that are mentioned needing a drill are regular phillips screws and, are indeed incredibly tough to get out without a drill. Though, the ones in my Gameboy were somehow already stripped pretty badly.)
Dayna - Responder
DEFINITELY do NOT need to use a drill to open a Gameboy Color!
Thomas Nunya - Responder
Exactly! I've watched plenty of repair and restoration videos regarding Gameboy Color systems and NONE of them use a drill
David Hannum -
The 6 screws to open the case ARE NOT PHILLIPS! They are Tri-Wing, a Y shaped driver, not + shaped. If you use a phillips head screwdriver, you will strip them quickly, and then you actually will have to drill them out. Use the right tool every time!
theneovega - Responder
I had to open it up once because I forgot to connect the ribbon, but thanks for the guide! It was quite helpful.
Dillon Henry - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 64
Últimos 30 dias: 309
Duração total: 54,802
