Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Game Boy Color, use o nosso manual de serviço.
  1. Game Boy Color Teardown, Game Boy Color Teardown: passo 1, imagem 1 %32
    • Take the Game boy and notice the way that it has been injection molded using two tools on the injection molder. The first thing to do is to separate these parts.
    Pergunte ao FixBot
  2. Game Boy Color Teardown: passo 2, imagem 1 %32
    • Remove the Game Boys battery case from the back of the game boy and take out any batteries that are inserted. this will leave you with the back panel.
    Pergunte ao FixBot
  3. Game Boy Color Teardown: passo 3, imagem 1 %32
    • The Two screws at the top of the back panel can be unscrewed using a Y-triwing screwdriver.
    Pergunte ao FixBot
  4. Game Boy Color Teardown: passo 4, imagem 1 %32 Game Boy Color Teardown: passo 4, imagem 2 %32
    • The two panels are snap fitted so you will need to pop them part use something to wedge the crack open.
    Pergunte ao FixBot
  5. Game Boy Color Teardown: passo 5, imagem 1 %32 Game Boy Color Teardown: passo 5, imagem 2 %32
    • To remove the main board just remove the 4 screws in the back doing this will mean you can take the board out of the abs plastic sections.
    Pergunte ao FixBot
  6. Game Boy Color Teardown: passo 6, imagem 1 %32 Game Boy Color Teardown: passo 6, imagem 2 %32 Game Boy Color Teardown: passo 6, imagem 3 %32
    • The metal cassette holder on the back plastic panel can be removed by simply using a small screw driver in all four corners this should mean it pops off.
    Pergunte ao FixBot
  7. Game Boy Color Teardown: passo 7, imagem 1 %32 Game Boy Color Teardown: passo 7, imagem 2 %32
    • The small plastic switch should just fall out of the plastic case make sure not to lose this when opening up the game boy.
    Pergunte ao FixBot
  8. Game Boy Color Teardown: passo 8, imagem 1 %32
    • You can simply pull the foam off the back of the screen pulling off the glue try not to tear the foam this makes things easier later.
    Pergunte ao FixBot
  9. Game Boy Color Teardown: passo 9, imagem 1 %32 Game Boy Color Teardown: passo 9, imagem 2 %32 Game Boy Color Teardown: passo 9, imagem 3 %32
    • Once the foam is off you can pull the main connection of the screen out this is the brown part of plastic sheeting it simply slides out.
    Pergunte ao FixBot
  10. Game Boy Color Teardown: passo 10, imagem 1 %32 Game Boy Color Teardown: passo 10, imagem 2 %32
    • The rubber buttons can easily be pulled off they are not held in but will need a little pull.
    Pergunte ao FixBot
  11. Game Boy Color Teardown: passo 11, imagem 1 %32 Game Boy Color Teardown: passo 11, imagem 2 %32 Game Boy Color Teardown: passo 11, imagem 3 %32
    • All the other buttons should just fall out. Be careful not to drop or lose these parts because they will come loose.
    Pergunte ao FixBot
  12. Game Boy Color Teardown: passo 12, imagem 1 %32 Game Boy Color Teardown: passo 12, imagem 2 %32 Game Boy Color Teardown: passo 12, imagem 3 %32
    • Pull the screen out of the game boy and take the front panel of plastic away and move it to the side.
    Pergunte ao FixBot
  13. Game Boy Color Teardown: passo 13, imagem 1 %32
    • Peel of the protective film on the LCD screen and remove the LCD screen from the casing.
    Pergunte ao FixBot
  14. Game Boy Color Teardown: passo 14, imagem 1 %32 Game Boy Color Teardown: passo 14, imagem 2 %32
    • The metal on the screen can be pulled off by getting under it with your fingers this is stuck with a tape.
    Pergunte ao FixBot
  15. Game Boy Color Teardown: passo 15, imagem 1 %32 Game Boy Color Teardown: passo 15, imagem 2 %32
    • some parts of the circuit board can also be removed and looked at much closer such as the speakers and the LED lights on the product.
    Pergunte ao FixBot
Marcus Broughton
Membro desde: 03/09/10
397 Reputação
Autoria de 1 guia
9Comentários do guia
That feel when everything turns out perfectly. ^.^ Thanks a lot for the guide! I was able to switch out a few broken/worn out bits, and now it's working like new! Super hyped! Thank you so much!
(Also, the screws that are mentioned needing a drill are regular phillips screws and, are indeed incredibly tough to get out without a drill. Though, the ones in my Gameboy were somehow already stripped pretty badly.)
Dayna - Responder Compartilhar
DEFINITELY do NOT need to use a drill to open a Gameboy Color!
Thomas Nunya - Responder Compartilhar
Exactly! I've watched plenty of repair and restoration videos regarding Gameboy Color systems and NONE of them use a drill
David Hannum - Responder Compartilhar
The 6 screws to open the case ARE NOT PHILLIPS! They are Tri-Wing, a Y shaped driver, not + shaped. If you use a phillips head screwdriver, you will strip them quickly, and then you actually will have to drill them out. Use the right tool every time!
theneovega - Responder Compartilhar
I had to open it up once because I forgot to connect the ribbon, but thanks for the guide! It was quite helpful.
Dillon Henry - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 70
Últimos 30 dias: 321
Ao todo: 61,863
