Introdução
Facts about floppy disks
- The casings are hard
- The disks are floppy
- Once opened, they don't go back together
- They're old.
O que você precisa
The floppy disk has gone the way of the dinosaur.
Except for Google's lovable jumping dinosaur.
These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
It's worth noting that today's photos taken can be upwards of 10MB on their own!
With some careful prying, the entire lid pops right off.
You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
And we get a glimpse of what's inside! Spoiler alert: not much is there.
On the inside, we see a small pad, probably to clean the turning disk that's inside.
This one was pretty nasty. Eww.
This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
The meat n' bones of the floppy disk, the disk itself!
Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
This antique technology has virtually no replacement parts.
Replacement of the tape or cleaning pads are impossible without breaking the case.
The cleaning pads are held on with tight adhesive, making replacement difficult.
Attempts to use heat to loosen adhesive may result in the case melting.
High susceptibility to magnets make this device very sensitive.
10 comentários
Super cool! Haven't seen a floppy disk in forever.
They are a tad old...haha
This is amazeballs. Solid work!
Great teardown! :)
