Ir para o conteúdo principal
Este teardown está em andamento – Atualizar periodicamente para ver as últimas alterações!
O que você precisa
  1. Fitbit Zip Teardown, Fitbit Zip Teardown: passo 1, imagem 1 %32 Fitbit Zip Teardown, Fitbit Zip Teardown: passo 1, imagem 2 %32 Fitbit Zip Teardown, Fitbit Zip Teardown: passo 1, imagem 3 %32
    • Use your iFixit Pro Tech Knife to slice and pry the different colored front and rear cases apart, as shown
  2. Fitbit Zip Teardown: passo 2, imagem 1 %32 Fitbit Zip Teardown: passo 2, imagem 2 %32
    • Remove the logic board/display assembly from the rear case
  3. Fitbit Zip Teardown: passo 3, imagem 1 %32 Fitbit Zip Teardown: passo 3, imagem 2 %32
    • Use your knife to slice off the bottom edge of the sticker found here on the rear of the board
  4. Fitbit Zip Teardown: passo 4, imagem 1 %32 Fitbit Zip Teardown: passo 4, imagem 2 %32 Fitbit Zip Teardown: passo 4, imagem 3 %32
    • Use a spudger to gently pry the display away from the logic board
    • Pry softly in each corner of the display, under the black frame
  5. Fitbit Zip Teardown: passo 5, imagem 1 %32
    • Seems to be it. The display doesn't appear to be separable from the logic board, sadly, making repairability completely out of the question.
Nathanael
Membro desde: 02/03/14
959 Reputação
Autoria de 2 guias
Equipe
Beautiful Savior Lutheran Church Membro de Beautiful Savior Lutheran Church
Business
1 Membro
Autoria de 3 guias
2 comentários
The display can be separated from the logic board, just pull it free from the logic board connector.
Yuri Silkin - Responder
My fitbit zip came apart at the seams. I decided to go ahead and clean the screen off since it was coming apart already and the screen looked dusty. Any ideas on how to put it back together? I goes back together and when I hold it everything functions, but I can't get it to stay together. Silicone? Glue? Any suggestions?
sweeney todd - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 2,257
