Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Fisher Price Laugh and Learn Around the Town, use o nosso manual de serviço.
  1. Fisher Price Laugh and Learn  table Teardown [April Fools ...], Overview: passo 1, imagem 1 %32
    • The table has 4 different play regions: Puppy's home, the market, the zoo and the farm
    • It also has the phone. Designed to call Puppy and friends.
    Pergunte ao FixBot
    Comentar
  2. Fisher Price Laugh and Learn  table Teardown [April Fools ...], Detaching the legs: passo 2, imagem 1 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], Detaching the legs: passo 2, imagem 2 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], Detaching the legs: passo 2, imagem 3 %32
    • All 4 legs removed
    • Each leg has a giant clip, that holds it in place. There is a neat tab to detach it from the table (see pictures)
    Pergunte ao FixBot
    Comentar
  3. Fisher Price Laugh and Learn  table Teardown [April Fools ...], The batteries: passo 3, imagem 1 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], The batteries: passo 3, imagem 2 %32
    • "Laugh and Learn" is powered by 3 AA batteries
    • Depending on usage and type of the battery they deliver between 3 to 24 months of fun
    • The battery compartment has a gasket to protect the batteries from water (or other liquids) - very thoughtful of a typical user
    Pergunte ao FixBot
    Comentar
  4. Fisher Price Laugh and Learn  table Teardown [April Fools ...], Peeking inside: passo 4, imagem 1 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], Peeking inside: passo 4, imagem 2 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], Peeking inside: passo 4, imagem 3 %32
    • After unscrewing 16 screws we can finally lift the bottom side
    • But be careful! There is a wire going from on/off switch that should be detached before removing it completely
    • The on/off switch wire connector
    Pergunte ao FixBot
    Comentar
  5. Fisher Price Laugh and Learn  table Teardown [April Fools ...], The main board: passo 5, imagem 1 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], The main board: passo 5, imagem 2 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], The main board: passo 5, imagem 3 %32
    • We love modular design!
    • The internal side of the main board features:
    • 60mm fan assembly with a single heat pipe and a tiny radiator
    • Authenticity label
    • Mini PCIe slot for wireless communication
    • DDR3 RAM slot, to buffer the audio effects
    • On the front side there is a tiny battery, that is probably used to back-up language settings
    Pergunte ao FixBot
    Comentar
  6. Fisher Price Laugh and Learn  table Teardown [April Fools ...], more details: passo 6, imagem 1 %32 Fisher Price Laugh and Learn  table Teardown [April Fools ...], more details: passo 6, imagem 2 %32
    • After removing the heatsink-and-fan assembly, the CPU is revealed
    • Intel i3-4005U CPU, featuring 2 cores (4 threads) running at 1.7 GHz and integrated HD4400 graphics, delivering the realistic experience of moving and talking animals and providing fast response for every button pressed on the device
    • The CPU is soldered down to the board, so there are no possible upgrades here
    • The wireless is powered by Qualcomm Atheros QCWB335 2.4GHz SB 1x1 Wi-Fi + BT 4.0
    • This is mid-2016 model. Nowadays mPCIe is obsolete, as all the major vendors use M.2 form factor.
    Pergunte ao FixBot
    Comentar
  7. Fisher Price Laugh and Learn  table Teardown [April Fools ...], The phone: passo 7, imagem 1 %32
    • This is a standard model used for Laugh and Learn. For privacy resons there are no cameras on this phone. Major specs:
    • Android 6 (Marshmallow)
    • 3.5" e-paper display. Our team was surprised by the quality - it really looks like a paper sticker!
    • 2 buttons: home and back
    • Snapdragon 600 series chipset with 3G modem
    Pergunte ao FixBot
    Comentar
  8. Fisher Price Laugh and Learn  table Teardown [April Fools ...], Summary: passo 8, imagem 1 %32
    • The device is firmly built and easy to disassemble/repair. The only drawback is soldered down CPU
    • If we were asked about repairability score - the answer is 17
    • Thanks for reading this teardown!
    Pergunte ao FixBot
    Comentar
Forest
Membro desde: 11/17/16
625 Reputação
Autoria de 3 guias
17Comentários do guia
Do you think you folks will be doing a Teardown for the rev. 2 logicboard? The Xeon’s cooling system looks like it’s permanently sealed shut (non-refillable) and I can’t figure out how to remove the GPS antennae
placebomessiah - Responder Compartilhar
Do you think it world be possible to pop the piano keys off to clean them underneath? My 1/red button is sticky and wears the batteries out really quickly
Catherine The Cool Mom - Responder Compartilhar
Yes, it is possible. Switch the toy OFF. You need a long phillips screwdriver to reach all the 16 screws on the bottom. Disconnect the power wire when you lift the plastic - see photo in Step 4. Then carefully unscrew the little green board (see Step 5, on the right) and you’ll be able to remove and clean the buttons. Placing the buttons back might be a bit tricky. Good luck!
That was actually the reason why I took it apart - my kid was drooling on the piano and half of the keys stopped working :)
Forest - Responder Compartilhar
Hi would someone be able to help me. The farm house door is not closing, spring came out so I've opened all up got the farm house out and I put everything together but I haven't got a clue where 2 springs are supposed to go.
dajanitta - Responder Compartilhar
Me pasó lo mismo, lograste ubicar en donde iban los resortes?
Lizzy Palvi - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 99
Ao todo: 7,529
