Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Fiio M6, use o nosso manual de serviço.
    • This is the full video guide, it begins after i tried to open it from the back. The device should be open from the screen.
  1. Fiio M6 Teardown: passo 2, imagem 1 %32
    • Heat the device to 110C for 2-3 minutes.
  2. Fiio M6 Teardown: passo 3, imagem 1 %32
    • Pry the sides of the device carefully (or not if your screen is shattered) . There are 8 plastic tabs holding the screen to the frame, with a little glue in each tab. The top tab is a big tab, so you must begin from the bottom.
  3. Fiio M6 Teardown: passo 4, imagem 1 %32
    • Disconnect the LCD ribbon connector in the middle of the frame and you can separate the LCD from the frame. At this point you can put a replacement LCD .
  4. Fiio M6 Teardown: passo 5, imagem 1 %32
    • Top view of the device opened, the battery is soldered with a little of conformal coating on top of the pads.
  5. Fiio M6 Teardown: passo 6, imagem 1 %32
    • Back view of the device, The part as identified:
    • ES9018Q2C DAC
    • ICN6211 MIPI LCD controller
    • Exynos 7270, this is a highly integrated chip for wearables, It includes the normal Samsung SOC characteristics, with stacked DRAM & eMMC integrated into the package. That is why the PCB don't have any DRAM or storage chips around.
  6. Fiio M6 Teardown: passo 7, imagem 1 %32
    • I removed the backplate, but for LCD or battery replacement is not necessary. The battery was glued to the back and there is an antenna on the top .
  7. Fiio M6 Teardown: passo 8, imagem 1 %32 Fiio M6 Teardown: passo 8, imagem 2 %32
    • Battery Detail.
    • Manufactured by SUNDA.
    • 3.7v to 4.2v
    • 1200mAh
    • 624736 pouch form factor
LazarusLong
Membro desde: 12/08/19
292 Reputação
Autoria de 2 guias
Um comentário
What are the dimensions of the battery?
Barry M. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 106
Duração total: 4,413
