O que você precisa
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Next let's remove the volume knob - you'll need a flat 2.5 bit for that. Carefully insert the bit into the hole on the rear side of the knob to undo a tiny screw inside of it.
That's it - chassis is free 👍.
Hint: use a plastic tray or a magnetic mat to safely store all of those screws and nuts. You can even write where all those parts come from.
