Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Seagate Expansion, use o nosso manual de serviço.
  1. Expansion Teardown, Open the cover: passo 1, imagem 1 %32
    • Using a flat head screwdriver or plastic tool
  2. Expansion Teardown: passo 2, imagem 1 %32
    • Remove the cover
  3. Expansion Teardown: passo 3, imagem 1 %32
    • Remove the drive from the case
  4. Expansion Teardown: passo 4, imagem 1 %32
    • Peel back the shielding
  5. Expansion Teardown: passo 5, imagem 1 %32
    • Remove the Screw with the #02 screw driver
  6. Expansion Teardown: passo 6, imagem 1 %32 Expansion Teardown: passo 6, imagem 2 %32
    • Separate the adapter form the sata port
Dan
Membro desde: 02/18/19
4.484 Reputação
Autoria de 9 guias
3 comentários
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - Responder
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - Responder
Answering a previous comment: yes, it is possible to replace the drive for one of different size. I replaced on of 3TB for one with 4TB and it is working perfectly.
Giovanni Bassi - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 45
Últimos 30 dias: 101
Ao todo: 4,711
