Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Space Heater, use o nosso manual de serviço.
  1. Essential Home HC-409 Teardown, Removed protective grill: passo 1, imagem 1 %32 Essential Home HC-409 Teardown, Removed protective grill: passo 1, imagem 2 %32 Essential Home HC-409 Teardown, Removed protective grill: passo 1, imagem 3 %32
    • Remove the grill from corner to corner.
  2. Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: passo 2, imagem 1 %32 Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: passo 2, imagem 2 %32
    • Carefully remove the screws and place them aside.
  3. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: passo 3, imagem 1 %32 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: passo 3, imagem 2 %32 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: passo 3, imagem 3 %32
    • As seen in the pictures, set the screwdriver on the edge of the cover and pry it out.
  4. Essential Home HC-409 Teardown, Remove safety sticker: passo 4, imagem 1 %32 Essential Home HC-409 Teardown, Remove safety sticker: passo 4, imagem 2 %32
    • Remove sticker in order to open the plastic casing of the heater.
  5. Essential Home HC-409 Teardown, Pry the product in half: passo 5, imagem 1 %32 Essential Home HC-409 Teardown, Pry the product in half: passo 5, imagem 2 %32
    • Slowly and carefully pry the plastic casing.
  6. Essential Home HC-409 Teardown, Remove the switch: passo 6, imagem 1 %32 Essential Home HC-409 Teardown, Remove the switch: passo 6, imagem 2 %32
    • Apply pressure onto the sides of the switch while pushing it outwards.
  7. Essential Home HC-409 Teardown, Remove fan: passo 7, imagem 1 %32 Essential Home HC-409 Teardown, Remove fan: passo 7, imagem 2 %32 Essential Home HC-409 Teardown, Remove fan: passo 7, imagem 3 %32
    • Unscrew the four screws located in the rear of the device. Remove the fan.
Garland Poon
Membro desde: 04/03/12
126 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-8, Forte Spring 2012 Membro de Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
Membros da 5
Autoria de 17 guias
Um comentário
I keep having problems with that little part that looks like a pen cap - white plastic. Is it a connector ou a fuse?
Cristina S - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,480
