Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Easter Egg, use o nosso manual de serviço.
  1. Easter Egg Teardown, Easter Egg Teardown: passo 1, imagem 1 %32
    • So let's find out what's inside this DELICIOUS-looking Easter egg.
  2. Easter Egg Teardown: passo 2, imagem 1 %32
    • First step - cut into the egg.
    • I wonder what kinds of things I'll find inside? Leprechauns? Little bunnies? The true meaning of Easter? Only time will tell.
  3. Easter Egg Teardown: passo 3, imagem 1 %32
    • The innards reveal a yellowy substance. Not sure what it is, but let's dig into it some more and see if we can find out.
  4. Easter Egg Teardown: passo 4, imagem 1 %32
    • Another cut is made, more yellow is found.
    • Surprisingly, no processors have so far been found. No bunnies for that matter, either.
  5. Easter Egg Teardown: passo 5, imagem 1 %32
    • Two halves exposed... But what's the yellow stuff? Only one way to find out.
    • Current bill of materials:
    • Yellow mystery stuff inside
    • Pink outer layer
    • Blue swirls
    • Yellow dots
    • Red Swirls
    • Green swirls
  6. Easter Egg Teardown: passo 6, imagem 1 %32
    • A formal analysis found that the yellow inner filling was, in fact, yellow cake.
    • Conclusion: Easter eggs rock!
3 comentários
You have a low tolerance for fainting.
Miroslav Djuric -
"This teardown is not a repair guide. To repair your Easter Egg, use our service manual" That's great. But how do I repair my pink Easter egg?
Michael - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 5,915
