Introdução
I will teach you how to dissect a Dualshock 2 controller, along with teach you a bit about how the device works
O que você precisa
There are 6 screws that you will want to remove on the back of the Dualshock 2 controller. All pictures show the same thing essentially, but because of Ifixit's odd picture cropping system, every screw appears at least once throughout the 3 photos.
Each of these buttons has a tiny curved disk attached to its bottom. This disk is very conductive. When the button is pressed, the disk is pushed against a thin conductive strip mounted on the controller's circuit board.
If the button is pressed lightly, the bottom part of the curved disk is all that touches the strip, increasing the level of conductivity slightly. As the button is pressed harder, more of the disk comes into contact with the strip, gradually increasing the level of conductivity.
This varying degree of conductivity makes the buttons pressure-sensitive (meaning pushing the button harder does have some merit to it)!
The final great feature about the dualshock 2 controller is it’s vibration feature. In a racing game, when you slam into a wall, you can feel the impact in your hands! The specific name for this is Force Feedback.This provides a tactile feature to the controller, allowing you to feel a sensation, even when you may not see it.
Force feedback is accomplished through the use of a very common device, a simple electric motor. In the Dualshock 2 controller, two motors are used, one in each handgrip. The shaft of each motor holds an unbalanced weight. When power is supplied to the motor, it the weight spins.
Because the weight is unbalanced, the motor tries to wobble. But since the motor is securely mounted inside the controller, the wobble translates into a shuddering vibration of the controller itself.
Um comentário
Super je me suis toujours demandéé à quoi servait le “tube” sur le cordon !
