Ir para o conteúdo principal
Disassembling of HP 625 Laptop Teardown Guide
O que você precisa
  1. Disassembling of HP 625 Laptop Teardown Guide, Teardown Guide: passo 1, imagem 1 %32
    • Overview of Hp 625.
  2. Disassembling of HP 625 Laptop Teardown Guide: passo 2, imagem 1 %32
    • Front View of Hp 625.
  3. Disassembling of HP 625 Laptop Teardown Guide: passo 3, imagem 1 %32
    • Removal of Hp 625 Battery.
  4. Disassembling of HP 625 Laptop Teardown Guide: passo 4, imagem 1 %32
    • Removing of Hp 625 Battery.
  5. Disassembling of HP 625 Laptop Teardown Guide: passo 5, imagem 1 %32
    • Hp 625 Battery Removed.
  6. Disassembling of HP 625 Laptop Teardown Guide: passo 6, imagem 1 %32
    • Unscrewing Hp 625 Service Door (4 Screws).
  7. Disassembling of HP 625 Laptop Teardown Guide: passo 7, imagem 1 %32
    • Removing Hp 625 Service Door.
  8. Disassembling of HP 625 Laptop Teardown Guide: passo 8, imagem 1 %32
    • Hp 625 Service Door Removed.
  9. Disassembling of HP 625 Laptop Teardown Guide: passo 9, imagem 1 %32
    • Unscrewing Hp 625 HDD, (3 Screws).
  10. Disassembling of HP 625 Laptop Teardown Guide: passo 10, imagem 1 %32
    • Removing of Hp 625 HDD, (Gently Slide).
  11. Disassembling of HP 625 Laptop Teardown Guide: passo 11, imagem 1 %32
    • Hp 625 HDD Removed.
  12. Disassembling of HP 625 Laptop Teardown Guide: passo 12, imagem 1 %32
    • Unscrewing of Hp 625 DVD Drive, (1 Screw)
  13. Disassembling of HP 625 Laptop Teardown Guide: passo 13, imagem 1 %32
    • Removing of Hp 625 DVD Drive, (Carefully Slid).
  14. Disassembling of HP 625 Laptop Teardown Guide: passo 14, imagem 1 %32
    • Hp 625 DVD Drive Removed.
  15. Disassembling of HP 625 Laptop Teardown Guide: passo 15, imagem 1 %32
    • Removing of Hp 625 DDR3 RAM, (Together With Two Hands Expand The Clips a little).
  16. Disassembling of HP 625 Laptop Teardown Guide: passo 16, imagem 1 %32
    • Hp 625 DDR3 RAM Removed, ( Be sure not to Touch The Gold Plated Pinouts).
  17. Disassembling of HP 625 Laptop Teardown Guide: passo 17, imagem 1 %32
    • Unscrewing of Hp 625 Keyboard, (6 Screws Noted By Keyboard icon).
  18. Disassembling of HP 625 Laptop Teardown Guide: passo 18, imagem 1 %32
    • Removing of Hp 625 Keyboard Flex Cable, (Gently Release The Locking Mechanism).
  19. Disassembling of HP 625 Laptop Teardown Guide: passo 19, imagem 1 %32
    • Hp 625 Keyboard Removed.
  20. Disassembling of HP 625 Laptop Teardown Guide: passo 20, imagem 1 %32
    • Disconnecting of Hp 625 Power Flex Cable From Connector, ( Fairly Unlock The Locking Mechanism).
  21. Disassembling of HP 625 Laptop Teardown Guide: passo 21, imagem 1 %32
    • Hp 625 Power Flex Cable Disconnected.
  22. Disassembling of HP 625 Laptop Teardown Guide: passo 22, imagem 1 %32
    • Unlocking of Hp 625 Palm Rest, Through The HDD Bay.
  23. Disassembling of HP 625 Laptop Teardown Guide: passo 23, imagem 1 %32
    • Disconnecting Touch Pad Flex Cable and Removing of Hp 625 Palm Rest.
  24. Disassembling of HP 625 Laptop Teardown Guide: passo 24, imagem 1 %32
    • Hp 625 Palm Rest Removed.
  25. Disassembling of HP 625 Laptop Teardown Guide: passo 25, imagem 1 %32
    • Unscrewing of Hp 625 System Casein, (16 or More Additional Screws Verify Very Well For Additional Screws Needed To Be Unscrewed Before Removing The Casein).
  26. Disassembling of HP 625 Laptop Teardown Guide: passo 26, imagem 1 %32
    • Removing of Hp 625 Front Casein, (Firmly Pry the Casein, Starting from Any Edge).
  27. Disassembling of HP 625 Laptop Teardown Guide: passo 27, imagem 1 %32
    • Hp 625 Front Casein Removed.
  28. Disassembling of HP 625 Laptop Teardown Guide: passo 28, imagem 1 %32
    • Unscrewing of Hp 625 Thermal Fan, (1 Screw).
  29. Disassembling of HP 625 Laptop Teardown Guide: passo 29, imagem 1 %32
    • Hp 625 Thermal Fan Removed.
  30. Disassembling of HP 625 Laptop Teardown Guide: passo 30, imagem 1 %32
    • Unscrewing of Hp 625 Thermal Conductive Heatsink, (6 Screws).
  31. Disassembling of HP 625 Laptop Teardown Guide: passo 31, imagem 1 %32
    • Hp 625 Thermal Conductive Heatsink Removed.
  32. Disassembling of HP 625 Laptop Teardown Guide: passo 32, imagem 1 %32
    • Unlocking of Hp 625 AMD Processor From Socket, (Anti-Clockwise).
  33. Disassembling of HP 625 Laptop Teardown Guide: passo 33, imagem 1 %32
    • Hp 625 AMD Processor Removed.
  34. Disassembling of HP 625 Laptop Teardown Guide: passo 34, imagem 1 %32
    • Disconnecting of Hp 625 Wi-Fi Cables From Wireless Card.
  35. Disassembling of HP 625 Laptop Teardown Guide: passo 35, imagem 1 %32
    • Hp 625 Wi-Fi Cables Disconnected.
  36. Disassembling of HP 625 Laptop Teardown Guide: passo 36, imagem 1 %32
    • Disconnecting of Hp 625 HDD Card From Motherboard.
  37. Disassembling of HP 625 Laptop Teardown Guide: passo 37, imagem 1 %32
    • Disconnecting All Cables of Hp 625 Connected To Motherboard.
  38. Disassembling of HP 625 Laptop Teardown Guide: passo 38, imagem 1 %32
    • Unscrewing Hp 625 Motherboard.
  39. Disassembling of HP 625 Laptop Teardown Guide: passo 39, imagem 1 %32
    • Removing of Hp 625 Motherboard.
  40. Disassembling of HP 625 Laptop Teardown Guide: passo 40, imagem 1 %32
    • Hp 625 Motherboard Removed.
  41. Disassembling of HP 625 Laptop Teardown Guide: passo 41, imagem 1 %32
    • Complete Disassembled Parts and Components of Hp 625.
  42. Disassembling of HP 625 Laptop Teardown Guide: passo 42, imagem 1 %32
    • 'Reparatur ist edel
Conclusão
9 outras pessoas executaram este guia.
samuel
Membro desde: 06/09/13
391 Reputação
Autoria de 1 guia
3 comentários
You mentioned there are 6 keyboard screws. I can find only five. Can you be more specific (detailed) in where these screws exactly are. Thanks
simakos71 - Responder
Hello Simakos71, follow this YouTube link: https://youtu.be/91JQ596T0og to know strategic places the screws are located.
samuel -
Whats a good way to follow i really want to be repairing but i need your advice on how to start thanks
engiengimib@gmail.com
Ibrahim Musa Bello - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 11,791
