Introdução
Dewalt 1/4" Impact driver and battery teardown.
With the Gearbox removed we are left with the motor on one side and the light ring on the other.
Neutral: Trigger Locked
Forward
Reverse
When selector is neutral this tab keeps the trigger from being depressed
Gear box fits into housing as a press fit with two clips. Releasing the two clips allows the gear box to be freed from its housing.
Planetary gear set: reduce motor speed and increase torque
Splines to gear box case
Internal teeth for planetary gear set
Spring (hard to see) for impact function: base spins and strikes output drive labeled with blue arrow in last picture
Remove four screws to open battery
Spring for latch to lock battery into tool
5 cells nominally 3.7V in series.
0V (GND)
12V (likely for LED light ring)
3.7V (not connected to tool)
18.5V
18.5V (main output)
