Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Dell Inspiron 1750, use o nosso manual de serviço.
  1. Dell Inspiron 1750 Teardown, Battery: passo 1, imagem 1 %32 Dell Inspiron 1750 Teardown, Battery: passo 1, imagem 2 %32
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Teardown: passo 2, imagem 1 %32 Dell Inspiron 1750 Teardown: passo 2, imagem 2 %32
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Teardown, Dell Inspiron 1750 Teardown: passo 3, imagem 1 %32
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Teardown: passo 4, imagem 1 %32 Dell Inspiron 1750 Teardown: passo 4, imagem 2 %32 Dell Inspiron 1750 Teardown: passo 4, imagem 3 %32
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Teardown: passo 5, imagem 1 %32 Dell Inspiron 1750 Teardown: passo 5, imagem 2 %32 Dell Inspiron 1750 Teardown: passo 5, imagem 3 %32
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Teardown: passo 6, imagem 1 %32 Dell Inspiron 1750 Teardown: passo 6, imagem 2 %32 Dell Inspiron 1750 Teardown: passo 6, imagem 3 %32
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Teardown: passo 7, imagem 1 %32 Dell Inspiron 1750 Teardown: passo 7, imagem 2 %32
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Teardown: passo 8, imagem 1 %32 Dell Inspiron 1750 Teardown: passo 8, imagem 2 %32 Dell Inspiron 1750 Teardown: passo 8, imagem 3 %32
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
Documentos anexados
Jordan Nedbailo
Membro desde: 04/07/14
687 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-3, Forte Spring 2014 Membro de Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 20,194
