Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua MP3 Player, use o nosso manual de serviço.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: passo 1, imagem 1 %32
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: passo 2, imagem 1 %32
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: passo 3, imagem 1 %32 Cowon iAudio 7 8GB Teardown: passo 3, imagem 2 %32
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
Membro desde: 03/24/14
210 Reputação
Autoria de 1 guia
3 comentários
2011music my songs
Tong Thao - Responder
Hi! Could you, please, say what the type of display is there?
tikhonte - Responder
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 25
Duração total: 4,368
