Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Commodore 1341 Joystick, use o nosso manual de serviço.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: passo 1, imagem 1 %32
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: passo 2, imagem 1 %32 Commodore 1341 Joystick Teardown: passo 2, imagem 2 %32 Commodore 1341 Joystick Teardown: passo 2, imagem 3 %32
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: passo 3, imagem 1 %32 Commodore 1341 Joystick Teardown: passo 3, imagem 2 %32 Commodore 1341 Joystick Teardown: passo 3, imagem 3 %32
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
Membro desde: 04/24/10
118 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 7,075
