Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Christmas tree, use o nosso manual de serviço.
  1. Christmas Tree Teardown, Christmas Tree Teardown: passo 1, imagem 1 %32
    • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
  2. Christmas Tree Teardown: passo 2, imagem 1 %32 Christmas Tree Teardown: passo 2, imagem 2 %32
    • First order of business: presents!
    • Use caution and joy when opening your presents.
  3. Christmas Tree Teardown: passo 3, imagem 1 %32 Christmas Tree Teardown: passo 3, imagem 2 %32
    • Disconnect the power plug
    • Remove the power socket, should there be one on your tree.
  4. Christmas Tree Teardown: passo 4, imagem 1 %32
    • To remove the baubles, lift them gently and untangle the string from the branch.
  5. Christmas Tree Teardown: passo 5, imagem 1 %32 Christmas Tree Teardown: passo 5, imagem 2 %32 Christmas Tree Teardown: passo 5, imagem 3 %32
    • If you find a capacitor on your christmas tree, straighten its leads to detach it.
    • All discrete electronic elements should be removed in this manner.
  6. Christmas Tree Teardown: passo 6, imagem 1 %32
    • Protective hand-wear may come in handy.
  7. Christmas Tree Teardown: passo 7, imagem 1 %32
    • Remain gentle, even when an element is very difficult to untangle.
  8. Christmas Tree Teardown: passo 8, imagem 1 %32 Christmas Tree Teardown: passo 8, imagem 2 %32
    • To remove the top ornament, lift it upwards.
  9. Christmas Tree Teardown: passo 9, imagem 1 %32
    • Finally, remove the lights.
    • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
  10. Christmas Tree Teardown: passo 10, imagem 1 %32 Christmas Tree Teardown: passo 10, imagem 2 %32
    • Before you run around barefoot in celebration, clean up.
    • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
    • The christmas tree is disassembled!
    • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
    • Thank you for reading, hope you are having a happy holiday.
    • Fix yourself a wonderful New Year in 2025!
baq
Membro desde: 10/14/09
305 Reputação
Autoria de 3 guias
Um comentário
skuirel sed it good!
Kyle Wiens - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 8,756
